How do you get plastic into your mold on your machine kevin? from the picture it looks like you pour it in from the top?
if its gravity fed there wont be and explosion.
To have and "explosion" you have to have enough pressure build up in the system to overcome one of your machines clamps or the actually machine body. If your pump cant do this then the system will just stall.
An explosion implies flying debris, if i just leaks then well....you know, no explosion.
although safety precautions should be taken for an explosion I think a more likely outcome is burnt plastic and no flow do to melt/viscosity issues.
But im not and expert...just and armchair engineer. Ignore me
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
