The ISO graphic nicely shows gross problems but it would be really nice to have a numerical display of the maximum Z-axis depth of each tool at the beginning of a run.
HI Ken, that is an interesting thought. What would you expect to learn from knowing that ??? PP has a view function that appears to only display the current tool toolpathing would that help ?? I am not sure it actually does that (;-) though.
(;-) TP
I might avoid a collision between my vise jaws and a tool! For example, I mostly do one-offs and frequently hold stock with Talon Grips. Typically I cut to within 0.01 or so of the grips. Due to senior moments I sometimes err. It is impossible to see the difference between 0.275 deep and 0.285 deep just by looking at the ISO view but a quick check of the numbers by tool would make such mistakes obvious. There is currently a display of toolpath extents but without tool numbers there is no way to know whether a deep cut is a drill in the centre of the stock or a clearing tool that will collide with the vise jaws.
OK I see where you are going with that. It really would not be that hard to parse the Gcode from Tool to tool and retrieve the lowest Z value then post it on the screen Just below where it displays the tool length. Then when the tool number changes so does the Z extents for that tool. Good idea (;-)
Have you ever tried to view the toolpath using the current tool only ?? I wonder if the extents change in the display ??
(;-) TP
I think that function is busted (;-) It sure works ODD.
(;-) TP
