587,221 active members*
3,053 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > GSimple (Free 3 Axis CAM) Version 1.08
Page 4 of 4 234
Results 61 to 72 of 72
  1. #61
    Feb 2007
    41
    Version 2.04 will be out in about a couple of weeks. The major improvement over the last version is the inch mode -it has been redisigned and the old problems (small deviations in the data) have been eliminated. Version 2.04 is currently in the debug state.
  2. #62
    Feb 2007
    41
    GSimple Version 2.04
    At last the new version is out and can be downloaded at http://www.gsimple.eu
    The installation method has been changed completely and there is also a new users manual which is (almost) complete.
  3. #63
    Aug 2009
    Hello to any g-simple users. I am looking to see if anyone has set up g-simple with a bridgeport set with sx15. I am looking for a config file or how to set up the config file for a bridgeport. Thank you in advance.
  4. #64
    Jul 2007
    8
    When will there be another update?
    I still use 2.03 the later ones had problems in INCH mode.
  5. #65
    Dec 2008
    4
    Hi Sotiris: I am learning how to use your program and I have to say it is great. Congratulations!!! Gsimple works very well creating the g-code in my pieces. I will try to cut some of them soon. I will be reporting my adventure. Thanks a lot!!!!
  6. #66
    Dec 2009
    4
    When I go to make the g code I come up with the error of: No engraving tool present for text ID 2. I have added the tools under the Tools tab and in the setup and still come up with the same error. Is there a tutorial that expands about engraving and the setup?
  7. #67
    Feb 2010
    84
    Can I not snap to an object to select line ends? Snap is on, all selections in snap options are turned on. I would think selecting LINE would allow a "pick" feature or something other than coordinates. Coordinates will be awful slow, error ridden drawing methods.
  8. #68
    Feb 2010
    84
    oops.
  9. #69
    I would just like to say that Gsimple is a brilliant programme and that it has helped me enormously in coming to terms with G-Code.
    I have used it to make quite complicated parts and once you have found all the wrinkles it is a very powerful tool.
    I use it to produce G-Code for my Denford Novamill that is running on Mach3.
  10. #70
    Gsimple is great
Name:	Parts Photo 002a.jpg
    OOPS!
    Double post. So I will give you a picture. ;-)
  11. #71
    Jul 2009
    56
    Re: GSimple Version 2.04
    S.Kontogiannis,
    Where has the gsimple download been moved to? The stated URL does not download.
  12. #72
    Aug 2013
    4
    Quote Originally Posted by keith20mm View Post
    S.Kontogiannis,
    Yes I was wondering thos as well I would like to use this program does anyone have a link where I could download it?
Page 4 of 4 234
  1. NCPlot free version - need help
    By bll230 in forum NCPlot G-Code editor / backplotter
    Last Post: 06-12-2010, 06:00 PM
  2. GSimple (Free 2 1/2 axis CAD/CAM) goes 3D
    By S.Kontogiannis in forum News Announcements
    Last Post: 11-03-2008, 11:35 PM
  3. GSimple Free CAD-CAM Version 2.00
    By S.Kontogiannis in forum Uncategorised CAM Discussion
    Last Post: 03-05-2008, 10:45 PM
  4. ProgeCAD free version
    By dleroi in forum Uncategorised CAM Discussion
    Last Post: 01-16-2008, 09:29 PM
