588,493 active members*
4,589 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Wiring HuangYang VFD without grounding! How dangerous is this?
Page 4 of 5 2345
Results 61 to 80 of 87
  1. #61
    Jun 2012
    153
    Re: Wiring HuangYang VFD without grounding! How dangerous is this?
    An inductor/choke between the Motor and VFD Drive only helps to protect the Motor, an Inductor or Filter before the VFD help to protect the VFD Drive
    An inductor between the Motor and VFD is not normally used for short cable length, but a input power filter or inductor is more important
    I thought an input filter was to prevent noise getting back onto the supply.
  2. #62
    24221
    The 3ph inductor protects both motor and VFD, at least the technical bulletins I have ever received from the leading international VFD manufacturers (Not Chinese!) that I have used, Virtually the same reason there is a choke fitted to DC outputs of low frequency DC motor controllers.
    The filter on the input is mainly for power factor protection and the supply Before the VFD.
    I just attended a 2 day seminar by the Provincial Electrical Hydro Service engineers here on the very subject.
    In all the years I have been installing these system I have never yet used a Input filter/inductor, to my knowledge, there has never been a failure by any of my installations using the inductor only on the VFD output.
    True!
    Plus P.F.Corr..
    Albert E.
  3. #63
    15362
    Most VFD Drive manufactures will tell you different, so i'm not sure what you are looking at, it is easy to find what I said is correct
    Mactec54
  4. #64
    15362
    Quote Originally Posted by reg.miller View Post
    Input line reactors protect the VFD drive from transient overvoltage conditions typically caused by utility capacitor switching. Input line reactors protect the front end electronics and also reduce the harmonics associated with AC drives, and are recommended for all installations.
    Output line (load) reactors protect the back end of the VFD Drive electronics and the motor insulation against AC drive short circuits and IGBT reflective wave damage, and also allow the motor to run cooler by “smoothing” the motor current waveform. They are recommended for operating “non-inverter-duty” motors, and for any motors where the length of wiring between the AC drive and motor exceeds 75 feet.
    There are many examples like this PDF
    Mactec54
  5. #65
    Aug 2010
    9
    Hi all,
    I need help , my Inverter is leakage 110v to case of spindle, this cause Z axis to move alone and not stop until cut off motors
    Anybody know what voltage in pins UVW ?, in my inverter have 110 oscilating to 150v in each pin
    My inverter model is 2.2Kw 220V monofasic
  6. #66
    15362
    Quote Originally Posted by jgomez View Post
    Hi all,
    If you have voltage to the spindle body then you have a short, check that the spindle plug wires are not touching the outside of the plug
    With the power disconnected check the spindle plug Pin1 to spindle body and the same for the other pins, if there is no short at this point then it is in your plug wiring that you attach to the spindle
    You can not measure the output voltage of the VFD with a regular multimeter you can damage the VFD Drive if you do this
    Mactec54
  7. #67
    Aug 2010
    9
    Hi Mactec54,
    Thanks for your reply, in pins UVW not have any short over spindle case, I use an Fluke True RMS to measures voltage in terminals.
    But when I start machining aluminum, from scratch the Z axis begins to descend without stopping I placing the multimeter between the ground of the Inverter X Spindle case I note the voltage of 100V
  8. #68
    Jun 2011
    692
    You need to ground your spindle case. At the very least a wire at least the size of the UVW wires directly from the case of the spindle motor to a good ground (preferably a star ground.)
    That may still not take care of your noise problem, and it may cause other problems to show themselves, but at least it will be safer, and is a first step to fixing your noise problem.
  9. #69
    Aug 2010
    9
    I have good ground bar with 2.4m and use 6mm wire to this is in Inverter pin marked as Ground.
    The trouble is intermitent, some times i use machine without any problem, but when see this, i have 100 / 110V between spindle case and inverter ground
    Any chance of my Inverter or spindle damaged ?
  10. #70
    Jun 2011
    692
    That's good that your inverter is grounded. Your spindle must also be grounded though. As is right now, a single wiring fault could put lethal voltage on the case of your spindle.
  11. #71
    Aug 2010
    9
    Many thanks skrubol,
    Later i do more test in my machine, but i do not undestand why this defect are intermitent
  12. #72
    Jun 2011
    692
    If you mean the Z axis movement, it's probably due to noise, and lots of external factors can influence that. It could come down to the position of the axis, where you're standing, the humidity, temperature, etc. Proper grounding and shielding are the way to reduce emitted noise (From the spindle and motors,) and reduce susceptibility to noise (signal wires to motor drives, and sensors/switches.)
  13. #73
    Aug 2010
    9
    I do not have any end stop in XYZ axis, machine work fine milling alluminum but while see the trouble, my Z axis dont stop move, in this case while Z axis move, i put multimeter between spindle case X ground in inverter and see 100/110V.
  14. #74
    15362
    Do you have a shielded cable from the VFD to the Spindle
    It can be quite normal to have a Ground voltage when the VFD Drive is running, yours does seem a little high for one of these spindles, the Rotor in the spindle will have a voltage that has to go to ground sometimes this can be quite high like you are seeing, this happens with all VFD Driven AC motors, that is why correct Grounding and Shielded Cables must be used and correctly terminated, post some photos of your wiring I may be able to see if there are any problems
    Mactec54
  15. #75
    15362
    Quote Originally Posted by skrubol View Post
    You can not do it this way by adding a Ground wire, if you added a Ground wire like this then it becomes an antenna
    Mactec54
  16. #76
    Jun 2011
    692
    Yes, but an antenna won't kill you (keep it out of thunder storms,) an ungrounded spindle can.
    If the ground is run close to the UVW wires it will help with noise as well. Not as good as a jacketed, shielded cable, but better than nothing.
  17. #77
    Aug 2010
    9
    I do not have shielded cable from VFD to Spindle, you can sugest one for me ?.
    And if possible, you can schematic how to do wire all cable from VFD > Gronding > Spindle
    In Brazil not easy bought shielded cables with good quality
  18. #78
    Aug 2018
    32
  19. #79
    24221
    Is this a Mill, i.e. moving XY table with stationary spindle?
    Al.
    Albert E.
  20. #80
    Aug 2010
    9
    Thnaks, But i am in Brazil, and very spensive to buy for in this location
    - - - Updated - - -
    Al.
    Not, spindle move with gantry X/Y
Page 4 of 5 2345
  1. Where can I get a manual for Huangyang 2.2 KW
    By futureform in forum Spindles / VFD
    Last Post: 09-07-2016, 11:31 PM
  2. Huangyang vfd HY07D543B 7.5 kw
    By BigDadyD in forum Phase Converters
    Last Post: 08-27-2016, 05:53 AM
  3. HUANGYANG VFD RAMP UP SPEED
    By pari in forum Spindles / VFD
    Last Post: 08-04-2016, 05:31 AM
  4. Actual settings for Huangyang 2.2 kw VFD
    By ajfoxy in forum Australia, New Zealand Club House
    Last Post: 07-31-2014, 04:35 AM
  5. Grounding, BOB's, and Wiring in General
    By Jkountz in forum CNC Machine Related Electronics
    Last Post: 01-10-2014, 02:13 AM
