588,531 active members*
8,023 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Torus Pro As A "Production" Machine
Page 4 of 73 234561454
Results 61 to 80 of 1459
  1. #61
    Jul 2006
    525
    Quote Originally Posted by HimyKabibble View Post
    Honestly, I don't know what your other options would be, other than either significantly less capable, or more expensive ones. The Tormach is, by all accounts, a very nice machine, but significantly, smaller and much lower performance. Beyond that, you're looking at machines that are probably 3X the price, or half the size. A DIY conversion will not come close to the performance and accuracy of this machine, unless you spend more on the parts than the Pro costs, in which case you *might* end up with a comparable machine a few years from now once you've finished wringing out the bugs.
    I am 100% satisfied with mine, and I haven't even put the servo kit on yet - still running steppers! It has proven dead-reliable, and provides performance at least as good as my 9x49 knee mill, with much greater accuracy and repeatability, and greater usable travels, except for the X axis (25" vs 32" on the knee mill). As a CNC machine, a bed mill is a FAR better configuration than a knee mill. The spindle is more powerful than the knee mill, and surface finish is, if anything, a bit better.
    A far as a video, tell me exactly what you're looking for, and I'll see what I can do. But it is hard to get anything clear, due to all the coolant splashing.
    Regards,
    Ray L.
    The other options are all more expensive, mostly comparing it to a used fadal. I have vast experience with them, and know it would be ideal for my purposes. However, added associated costs (tooling, power, etc) would really stretch (okay, triple) my budget. The novakon on the other hand would come In under budget, I'm just not entirely confident I'd be satisfied.
    Definitely holding out for the pdb and tool changes though.
  2. #62
    Jan 2007
    869
    I think it depends on the program you are using what they refer to it as. I wouldn't want to screw your machine up by sending code that I don't know for sure if it will work. I use sprutcam. I've done some of that kind of removal, but I have to be really careful as I only have 1hp. I'm just curious what effect the Torus Pro's stronger spindle would have on removal rates.
    Wade
    Wade,
    I have no tools for generating toroidal (I think you mean trochoidal?) toolpaths. If you want to send me some code, I'll run it.
    Regards,
    Ray L.
  3. #63
    Feb 2006
    7063
    Quote Originally Posted by wwendorf View Post
    Wade
    Wade,
    Power scales more or less linearly with MRR. So, if you have toolpaths that work well with 1HP, I'd expect the Pro to be able to do 1.5-2.0X that, unless rigidity becomes an issue, which I don't think it would with trochoidal toolpaths. If you've got something that works on your machine, I can try it here, and give you an idea "how much is left", and you can re-generate with more aggressive parameters, and we'll try again. Breaking the machine is not a concern - worst case, it'll just break a tool. If you don't break a tool once in a while, you're not working your machine hard enough! :-)
    "Toroidal toopath" doesn't even make sense, being that a toroid is a donut/bagel shape. I'd be leery of any CAM that referred to "toroidal" toolpaths, because it's simply wrong. The correct term is "trochoidal", because that basically describes the path the tool much take to maintain constant engagement through a corner, and constant engagement is the very core of all HSM methods.
    Regards,
    Ray L.
  4. #64
    Feb 2011
    605
    ^^^^ If you want to try some HSM paths I can program some tests for you in HSMWorks - it generates nice reliable code. Rob is also a very savvy HSMWorks user.
    PM-45 CNC conversion built/run/sold.
  5. #65
    Feb 2006
    7063
    Quote Originally Posted by jid2 View Post
    OK by me, if it'll give Wade what he's looking for. I can run well over 200 IPM (I've tested it over 300, and it seems reliable, but never actually run it at that speed)
    Regards,
    Ray L.
  6. #66
    Jun 2007
    3891
    Regards,
    Ray L.
    machine might do 200ipm, but mach3 may puke doing trochoidal at that speed. will be interesting to see anyway. i cut at 100-150 on my old one, and ran into the g64 bug a few times. this was only in wood though so the stalls never caused damage.
  7. #67
    Jul 2006
    525
    It might be unconventional, but the most successful uses of trochoidal milling I've had don't involve particularly high feed rates. My normal strategy is relatively deep axial and radial cuts at slightly increased feed rates.
  8. #68
    Jan 2012
    469
    Ray isn't using Mach3, so the higher feeds would be a nice test of KFlop as well!
  9. #69
    Jun 2004
    6618
    Do you guys have some video examples of what you are discussing? Sounds interesting.
    Lee
  10. #70
    Dec 2004
    783
  11. #71
    mach 3 can handle the high feedrate , provided it's setup right
    Trochoidal paths are ok if running at full flute depth , otherwise I've never seen much benefit since 1/2 the tool path is air cutting . I've tried that toolpath numerous times while roughing steel fixtures on the haas with insert mills and or endmills , I've found that I can get the job done literally twice as fast by running lighter depths with very high feed rates and a high spindle speed . A light machine may find trochoidal to have some advantage , simply because a light spindle can't take a heavy cut for long , so if the tool is intermittently engaged into the work piece then there isn't enough time to completely bog down the motor .
    I can see some possible advantage on steel jobs (depending upon the application) , I've seen guys use it for aluminum which I think is a bit pointless .
    Just to give an example of how little torque is needed , 1/2 way thru the vid I bump the feed rate to 120 ipm (it was a torture test on my wood router ) , otherwise if I had something with a bit more torque then I'd be able to rip thru it at a quicker rate without torchoidal
    cutting steel - YouTube
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  12. #72
    Jun 2008
    1082
    I recorded another video. I'm pretty sure this is what wwendorf was asking for. I think this cut would have worked a lot better if I was using a "rougher/finisher" bit instead of this standard one. The chips get pretty long at this depth (15 mm) and get tangled up pretty easily. The buildup combined with the deep slot (AKA poor cooling) proved to be too much this time. Anyway, here it is if anyone cares...
    00067 - YouTube
  13. #73
    Jul 2006
    525
    Slots like those will virtually always clear easier with a traditional cutting method. Its really only in very difficult materials where trochoidal will have an advantage there - and it will still be slower. Aluminum easily carries the heat generated by the cut away from the cutting area, so slotting will work just fine-- just try and make the chips "fountain" clear, if you have the horsepower.
  14. #74
    Jan 2007
    869
    Thank you for the post Hirudin. That definitely is what I wanted to see. Very impressive. Did you say you use HSM works to do the cuts?
    Tells me how well the Torus will do the cuts. I have a Tormach 770 now, which does everything I need, but I'm already looking for what my next machine will be. I might have gotten a Novakon, but I really needed an ATC and PDF and didn't have time to make one myself. When Novakon comes out with their PDB and ATC, I will be looking seriously at this combo for my next machine.
    Wade
  15. #75
    Jun 2008
    1082
    Thanks!
    I'm using SolidCAM myself. This slot was made with their "2.5D iMachining" add-on. I basically selected the two sides of the slot and pushed the "Calculate" button. (There's more to it of course, but that's the gist of it. ) Although there is a lot to like about SolidCAM I'm not sure if I'd recommend it. Then again I'm a newbie - the only other CAM package I've used extensively is RhinoCAM. I hate to go off topic too much though so I'll just leave it at that.
  16. #76
    Jan 2012
    469
    Traditional Machining of a Pocket Vs. iMachining of a Pocket - YouTube
    To me, this was the clearer comparison I found about the advantages of HSM toolpaths - not just trochoidal paths.. Trochoidal is a feature to be used in specific cases, but the real beauty of HSM (or constant engagement toolpaths..) is.. Well, the constant engagement. In this video, you can see the trochoidal is not any faster than traditional milling, but it prepares the way for the adapted spiral toolpath that is silly fast. Of course I'm sure the SolidCAM guys might have fudged the numbers a bit to make them look better, but still..
    On the other hand, notice the spindle speeds for both options! HSM is really designed for machines that can go a lot faster than most of our benchtop machines. The HSM path allows the spindle to go much faster, but if you're already maxed out with a traditional toolpath, you probably won't see an advantage anyway!
    They are fun to watch either way, so there's that
  17. #77
    Feb 2006
    7063
    True HSM operates at spindle speeds FAR beyond what any of these small machines can do - on the order of 5-10X what traditional milling would use. It is a fundamentally different way of removing material, and involves many different technologies, not just one specific type of toolpath. One of the primary features though is some means of achieving constant engagement, even when cutting corners, etc., which greatly increase load on the tool and spindle in conventional machining. Trochoidal paths are but one means of achieving this, under certain conditions. iMachining is a particularly interesting product, as they have their own unique algorithms for generating, from what I've read, better constant-engagement toolpaths than any other tool currently available. Of course, it ain't cheap, and you can imagine what happens if you program these things wrong....
    Regards,
    Ray L.
  18. #78
    Jul 2006
    525
    iMachining has very nice marketing algorithms, and the same toolpath algorithms as virtually everyone else.
    Don't believe the hype!
    For years, the algorithm was on license from Julian Todd and Martin Dunschen of Freesteel-- who developed it with support from Cimco, who originally owned HSMWorks. I'm not sure where Martin wound up, but Julian is still on the HSMWorks team at Autodesk.
    Surprisingly, when you make a programming error at those speeds, the resulting crash is usually less dramatic than you'd expect. The tool instantly snaps, unlike at lower speeds, where the tool will typically survive long enough to really do some harm
  19. #79
    Feb 2006
    7063
    Today I finished the last "volume" mechanical parts for the ignition kits - just a few odds and ends left to do then making the wiring harnesses. Yesterday and today I made the smallest, and most complex, parts of the entire kit - 88 of them. They are the little aluminum pieces at the ends of the spark plug wire organizer in this photo:
    Attachment 184152
    These are a PITA to make, because they're small (~3/4" x 1" x 1-1/2"), irregularly shaped, and they are machined on all six sides.
    Once I got that out of the way, I mounted my new LED flood-lights - same ones I have on my old machine. They provide MUCH better lighting than the halogen, with virtually no heat. I was able to run the wiring through the existing flex-conduit for the E-Stop and door switch. The wiring from there to the lights is just temporary at the moment. It will be into the head through grommetted holes right next to the lights.
    Through this whole production, the Pro has performed absolutely flawlessly - not a single problem of any kind.
    Regards,
    Ray L.
  20. #80
    May 2013
    42
    I am looking at the Tormach originally, and now this Torus. The ATC on the Tormach would be a plus however.
    The reason I like this machine so far, is I can get the lathe, which I will need. The price looks OK, and thank you for your thread, nice to see it in the real world running along.
    I plan to mill SS and grade 5 Ti though. Small-ish parts, and no hurry to finish each one, and not sure if this is the right size machine.
    The smaller I can use the better though, as I am short on space. So it is on my list of considerations, though I notice on their website no accuracy specs.
    One thing that concerns me a little is a website dedicated to rubbishing this brand. I have read his story, and see his point, but continue to look for more experiences, both good and bad to come to a decision. Yours is obviously good.
    The fact I am in Australia would mean I would not get support anyway, so realize I would need local help for any major issue.
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Need advice Setting Up production: 4 to 8 sq ft of 39" long 1x1" AL Angle daily use
    By aluminumwelder in forum Material Machining Solutions
    Last Post: 09-27-2013, 08:21 AM
  3. First "real parts" made on the Torus Pro
    By AUSTINMACHINING in forum Novakon
    Last Post: 05-30-2013, 04:06 AM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
