I had wired and rewired this thing so many times without any positive effect it was effecting my sleep. I don't know how many days I just sit there looking at that old control changing this, changing that all with the same results until I decided to scrap that whole control. I know you told me to do that many pages ago but, I am hard headed you know. What really caused me so much pain is the fact that I know it was working the day they unplugged it. Then when I plugged it in to my system it wouldn't. Add to that, this is the first time I ever attempted to build a RPC and I was having a hard time with getting the basics down. There is so much good and bad information out there sometimes it's hard to really know which is which. On top of all that throw in all the problems I had with those cheap parts that came in the kit I bought everything just led up to a big bag of mixed problems.
Im not really sure if any of the meters I have will read true RMS. I have an old Fluke 8020 B, a TPI 133 kit I bought for AC work, I have a MT 586 B that I bought from the snap on guy when I was working on boat motors that has all the bells and whistles, temp probe, and a bunch of other stuff I don't even know what it's used for. And of-course I have my old trusty Simpson 260 that always seems to be there when I need it. But for checking current I mainly use my old Amprobe clamp on meter. It will measure up to 600 volts and 300 amps and also ohms. That's the one I used to take the amp measurements.
I would like to one day to get this RPC a little closer with respect to line voltage as well as power factor. I have struggled with trying to get my head wrapped around how to accomplish this but the way this kit I bought is wired I keep coming up blank. There are only 4 capacitors in the whole system, 2 on the start side and 2 on the power side that are all wired together . One thing it does do well is start up this machine will be up and running before you can take your hand off the start button. Maybe they figured that if it started that was good enough and you won't supposed to worry about the rest.
I can't say enough again of how much I appreciate you hanging in there with me with getting this mess sorted out. Thanks!:cheers:
