588,084 active members*
4,914 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Cannot home x axis on 84 Brugmaster vtc 150 with Fanuc mainbd # A16b-1010-0050-036A
Page 4 of 4 234
Results 61 to 66 of 66
  1. #61
    May 2009
    98
    Re: Cannot home x axis on 84 Brugmaster vtc 150 with Fanuc mainbd # A16b-1010-0050-03
    Quote Originally Posted by alexfanuc View Post
    What is the value of parameter 10?
    The value is 00000001
    Thanks Alex
  2. #62
    Type in your program number first O1234 then press INSERT Now press the EOB Key then press INSERT. The controller will not accept the EOB in the same line the program if you have included the EOB with it. Must be done separately.
  3. #63
    May 2009
    98
    Quote Originally Posted by drdos View Post
    Thanks drdos, I will give it another shot tomorrow.
    Scott
  4. #64
    Aug 2009
    1573
    ...we can over come. the 11m was just a 6MB fanuc with softkeys....I perfured the 6MB or sister 6TB tech 1980's STD's with CRT's ..push buttons.
    have we stored the Params yet...
    leave the power ON to the Control....in EStop is a good Idea too.
  5. #65
    May 2009
    98
    I did as per your instructions and got the program number to be on a line by itself. Unfortunately that did not affect the problem with the control not running anything in G01 mode. I also installed the new DAC chip in the Fanuc motor drive hoping that was the problem with it not accepting speed command. That was a fail as well.Thanks for your help.
    Scott
  6. #66
    May 2009
    98
    Quote Originally Posted by machinehop5 View Post
    I have not stored the parameters yet. Will get it done this weekend. Short of someone knowing what is causing this G01 not running issue, I may have to just wait until I have time to retrofit to a Dynomotion setup. I have done that with two lathes and they work great. Thanks for your help.
Page 4 of 4 234
  1. fanuc mother board problem a16b-1010-210
    By frigoteknika in forum Fanuc
    Last Post: 12-07-2021, 02:45 PM
  2. Replies: 13
    Last Post: 01-30-2017, 08:05 AM
  3. DRIP FEEDING OM-A ..A16B-1010-0210
    By gabedrummin in forum Fanuc
    Last Post: 03-18-2014, 02:34 AM
  4. A16B 1010 0040
    By gglynn81 in forum Fanuc
    Last Post: 05-18-2008, 04:02 AM
