603,894 active members*
2,818 visitors online*
Page 4 of 15 2345614
Results 61 to 80 of 293
  1. #61
    Nov 2004
    30
    Tom
    How do you disable the brakes (is there a way to remove them without destroying the motor?)
    What's the lead time on the 2030 drive?
    Have you tested the 1000W motor yet?
  2. #62
    24260
    You are probabally better off to a constant supply 24vdc. In one case I just wound a secondary on the power supply toroid with a bridge and small electrolytic. the wire gauge can be small as it is less than 1amp load. This way the brake picks up whenever the power is on to the DC supply.
    Al.
    Albert E.
  3. #63
    May 2005
    11
    AC power supply for surplus motors
    So, say that these AC servos work with the rutex driver. Isn't the next step to design a power supply? Their is lot of info on making a DC power supply, but what about an AC supply.
    It appears that even with inexpensive AC servo and rutex drivers, it is still more then a gecko and a say, Ametec DC servo. ? What will a AC supply cost to make? Are these AC servo worth and extra $50-$75 per axis?
    Comments
    P
  4. #64
    35494
    You don't need AC, you use a DC supply to the Rutex. The Rutex is $85 more than a Gecko. The AC servo is $40, including a 2000 count encoder. Can you get a comparable DC servo with encoder for $125? I haven't seen any? I was planning on using Gecko 202 with Vexta 400 oz-in steppers on my next router. The AC servos and Rutex are cheaper.
  5. #65
    May 2005
    8
    Thanks to everyone for all the great info on these motors. I had been thinking steppers, because a servo system seemed way out of my budget. Thanks to all the encouraging info here I just put my order in for some 1000w. Only 41 left!!!
    Get them while you still can...
    I can't wait to see some of the great machines that will be made with these...
  6. #66
    May 2005
    11
    O.K. now 30 left
    So, yep ac servo are ordered. Any pointers on the power supply?
    What size of toroid for 4 servo setup, cap size, and rectifier size?
  7. #67
    May 2005
    925
    Can the encoders be used for something else, the $29 motor sound interesting for doing it. Thanks
    Pablo
  8. #68
    Jun 2003
    1365
    The motors are worthless without the encoders, the motors are worth much more than that, expecially at the quanity. I advize you not do that.
    Jon
  9. #69
    May 2005
    925
    I hate when this happens, the large motors are 17lbs each and maximum shipping allowed by USPS to Argentina is 44lbs...
    What size of fast router for cutting wood can be nicely done with the 400w ones? I want to take advantage of the deal but I have the 44lbs limit
  10. #70
    Jun 2003
    1365
    for a router, the 300w motors are great plenty...
    I ordered a few more motors, 3 300w and 1 more 400w(total of 4)
    Here is updated IGES and SLDPRT files of my motor that I measured.
    Jon
    Attached Files Attached Files
  11. #71
    Jun 2005
    476
    Down to 20!
    Wow, they're down to 20 motors left, down from 30 motors just over an hour ago! All those of you who were lurking and learning about the motor, are you now jumping on the chance at the last minute?
    I bought 6 of the 1kw's and they arrived very well packed, in the original unopened boxes, very obviously genuine Sanyo Denki packaging. The writing printed on the inside of the box is in Japanese.
    I am also excited to see what people will do with their motors! Two of my motors will end up on my router project:
    http://www.cnczone.com/forums/showthread.php?t=11786
    Here's a close-up of the wires coming out of the motor:
    Attached Thumbnails Attached Thumbnails sanyo-denki-1kw-arrived.jpg   sanyo-denki-box.jpg   sanyo-denki-wires.jpg
  12. #72
    Feb 2005
    38
    1000 watt'rs all gone!
    I know a lot of us are banking on the rutex drives working properly with these motors. We might see a bunch of these back on Ebay if they don't. Any more updates/results with rutex drives?
  13. #73
    Aug 2005
    86
    Well looks like the great motor goldrush of 2005 is basically over (some of the lower wattage motors are still left).
    I have a feeling there will be a lot of interesting discussion over the next weeks/months about using these motors. Also I have a feeling that Rutex might want to stock a few extra 2030s!
    I even ordered one of the 1 kW motors yesterday; maybe I'll use it as a spindle motor; maybe I just didn't want to be left out of the fun!
  14. #74
    Dec 2004
    518
    Quote Originally Posted by DerekZahn
    Well looks like the great motor goldrush of 2005 is basically over (some of the lower wattage motors are still left)....I even ordered one of the 1 kW motors yesterday; maybe I'll use it as a spindle motor; maybe I just didn't want to be left out of the fun!
    Yup, me too. Don't know why, as I don't even really need them. I guess it was just to good to pass up! Now for the power supply....
    Evodyne
  15. #75
    24260
    You may have noticed, the combined Sanyo-Denki supply and amplifier for one 1Kw motor is rated at 2.5Kw.
    Al.
    Albert E.
  16. #76
    Jun 2005
    476
    Quote Originally Posted by Al_The_Man
    Al.
    Al, where did you see that?
  17. #77
    Oct 2003
    170
    Gentlemen,
    I'm away until Monday evening. I did not get time to try the 1000 watt motor, but Vladimir said a similar motor he was aware of worked fine with the R992H. I'm confident they will work too-enough that I ordered 10 1000 watt motors myself. I warned him about the expected orders. He said he still has some R992H's to sell, and that there was a slight delay (caused by him being so busy programming some of the windows support programs for his plasma control) on the motors arriving by the first week of November as scheduled, but that they will be out real soon.
    Tom Eldredge
  18. #78
    24260
    Quote Originally Posted by damae
    PDF attached
    Al.
    Albert E.
  19. #79
    Oct 2005
    7
    Question Rutex R2030/1000W Sanyo motor braking resistors
    I have a thought regarding braking resistors for the Rutex R2030 drives and the Sanyo 1000W motors. How about putting a diode in parallel with the resistor in the direction that the current will bypass the brake resistor in normal mode and then block the current when we have back EMF (Similar to the body diodes of the MOSFETs in the H-bridge)? This way we only have the voltage drop over the diode under normal conditions and the resistor is doing its thing for back EMF. It should give us less power dissipation in the resistor as well. The diode needs to be rated for at least 20A continuously. Any problems with this approach?
    Mats
  20. #80
    Dec 2004
    518
    Gee, I wonder if SurplusCenter will be kind enough to offer those drives for, I don't know, $50.00 or so? Maybe if we ask real nice?? (...reality sets back in...) Um, probably not. :frown:
    Evodyne
