588,687 active members*
6,497 visitors online*
Page 4 of 4 234
Results 61 to 71 of 71
  1. #61
    Jan 2009
    25
    Quote Originally Posted by josiah47 View Post
    can you provide a list of parts/schematic that you used to build these drivers, or even a tutorial?
    Here is PCB layout for your reference!!!!!:bat:
    Attached Thumbnails Attached Thumbnails 5-Phase stepping Driver_PCB layout.PNG
  2. #62
    Jul 2007
    7
    Where I can buy this chip? SI-7510 + SLA5073 + SLA5074
  3. #63
    Oct 2004
    9
    Quote Originally Posted by kayo View Post
    incredibile ..this part SI7510 not exist in europe ....why?
  4. #64
    Jul 2007
    7
    HI josiah47
    Do you have schematic?
    Thank you.
  5. #65
    Jan 2009
    25
    Quote Originally Posted by stal View Post
    You can buy those parts in Hong Kong, let me know your skype ID or e-mail address, I will help you to buy those parts via internet, same I buy before.
  6. #66
    Oct 2012
    You Can buy SI-7510
    Contact me via email: [email protected] & skype:elek.tuyen
    SI-7510
    SLA5073
    SLA5074
    TB6560HQ/FG
    drv881
    Drv401A
  7. #67
    Jul 2010
    I built two drivers with the SI-7510 IC,
    they do work, but I am not getting the required speed or torque, on the test setup.
    I am using the original RMD596 5phase stepper motors (2.7A/phase, 120N.cm) from a EMCO turn 120 CNC lathe, that I am retrofitting.
    For the test setup I have:
    - a 555 timer for the step signal
    - 24V 15A PSU
    Some pics:
    The lathe:
    Test Setup:
    Board 2 (missing 2nd sense resistor):
    Schematic:
    I am stuck and don't know what to change to get the required performance, the motor lacks torque and is nowhere near what I need. Any help would be appreciated.
    I have a oscilloscope, and have measured the voltage across the sense resistor to peak at 2.4V -> 14.5A total with around 20% duty cycle, the current adjusting potentiometer has no effect on this, but it is at the max current that I am looking for.
    Also when running the motor for +- 1 min, the driver turns off and holds the stepper in place.
    The 0.33ohm, 5W sense resistors get quite hot, but the (p30nf10) transistors only get hot when the motor is stationary (I.E. no step signal or when it holds itself)
    the attached schematic is updated with current values, the board is not linked anymore and has some mistakes.
    Attached Files Attached Files
  8. #68
    Dec 2011
    Hello! I'm newbie in cnc. I have two 5ph vexta motors and two Si-7500A drivers for them. Сontrol sequence for this drivers is "2-3 phase excitation" . Can anybody explain me what does this logic sequence mean? Does it mean that only 2 or 3 coils can be excitated simultaneously? Like in this tutorial Jones on Stepping Motor Control Software
  9. #69
    Oct 2004
    9
    Quote Originally Posted by vubdub View Post
    Does it mean that only 2 or 3 coils can be excitated simultaneously?[/url]
    you can read this .
  10. #70
    Jan 2011
    It is just like a 3 phases act in 3 phase motor case especially three phase delta connection.
    no neutral no phase LOL.
    every wire changes +ve and -ve sequencing .I mean in a special pattern sequence.
  11. #71
    Sep 2018
    6
    Re: 5 Phase/ 5 wire stepper drivers.
    FWIW, parts are available in the US:
    SI-7510: $5.95 at DigiKey, https://www.digikey.com/product-deta...510-ND/4454412
    SLA-5073: $5.95 at DigiKey, https://www.digikey.com/products/en?keywords=SLA-5073
    LA5074: $4.76 at DigiKey, https://www.digikey.com/products/en?keywords=SLA5074
    Trinamic 2-, 3- and 5-phase stepper driver: TMC454, https://www.trinamic.com/fileadmin/a..._datasheet.pdf
Page 4 of 4 234
  1. Stepper motor&drivers,servo motors&drivers,motion control card CHINA factory
    By stepmotordriver in forum Manufacture Company Listing
    Last Post: 06-21-2014, 09:14 AM
  2. Possibility of driving 8 wire stepper motor with two TB6560 drivers ?
    By rajithilanga in forum Stepper Motors / Drives
    Last Post: 05-12-2014, 05:56 PM
  3. Running stepper motor wire with router wire?
    By basskitcase in forum DIY CNC Router Table Machines
    Last Post: 02-19-2010, 05:18 PM
  4. 2 phase driver & 4 phase 6 wire stepper HELP!
    By mark in aus in forum Stepper Motors / Drives
    Last Post: 06-02-2009, 06:31 PM
  5. Sine wave for 5 phase 10 wire stepper (non-stared)
    By terrym in forum LinuxCNC (formerly EMC2)
    Last Post: 09-29-2008, 10:57 AM
