603,359 active members*
4,746 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > 4 Axis Mach 3 Postprocessor (free but kinda wip)
Page 4 of 6 23456
Results 61 to 80 of 104
  1. #61
    Dec 2010
    32
    Re: 4 Axis Mach 3 Postprocessor (free but kinda wip)
    From the looks of it and since I'm at the office currently and cannot really spend time on it -- all the variables need to be moved to the prp, G89 - no idea, just delete it and the whole function if you don't use it.
    Since it's been quite some time since I last dealt with the old SC PP format - I think that the prp had the same format as the new format meaning that simply finding the variables near the top of the new file and cut-pasting / moving these lines to the prp. If that does not help, drop me a line and I will take a look when I have the time.
  2. #62
    Feb 2016
    Hello I look for a post pro featurecam 4 axis for mach3 !!
    Help !!
    tanks
  3. #63
    Dec 2010
    32
    @mich68 - can't help you with that, sorry.
    @rufan - Did you try it ? Any luck ?
  4. #64
    Feb 2016
    Tanks !
    Try(Essay) with fanuc post pro ! does not work!
  5. #65
    Feb 2016
    Tanks jailbreaker
  6. #66
    Dec 2010
    32
    Hey,
    I started implementing a new version of the post, having solidcam's new kinematics (pos_to_machine=1). As a result none of the ugly math is needed anymore for 4x and 5x movements. It also has proper drill cycles, trimmed comments and so on.
    I have posted the development files -- PostDevTestMachine.[vmid, gpp] on the github repo. The test machine is has the rotary axis parallel to Y. When development is done I will also make a version for X.
    Obviously testing is needed and any feedback appreciated.
    Cheers,
  7. #67
    Aug 2005
    13
    Dear jailbreaker,
    At the moment I use the post processor "Fanuc_2013_4x" posted on this form.
    Unit now it works very well. But when I make in SC Operation Transform and generate the G-Code and open it in Mach3 it finds unknown words.
    Mach3 cannot handle the While function.
    Do you know a solution for this?
    O1000 (SQ6MBRACKETHOLDER_MILLING.TAP)
    N1 G90 G17 G80 G40
    N2 G0 G21 G40 G49 G54 G80 G90 G91.1
    N3 G54 A-180.
    N4 T2 M06
    N5 G90 G0
    N6 G0 X-3. Y-5.998
    N7 G43 H2 G0 Z50. M3 S3714
    N8 M8
    N9 #21 = 0
    N10 WHILE [#21 LT 2] DO 1
    N11 G54 A-180. ( FM-facemill1 )
    N12 G0 A180.
    N13 (---------------------------)
    N14 (FM-FACEMILL1 - FACE-MILLING)
    N15 (---------------------------)
    N16
    N17 G0 X-3. Y-5.998 Z10.
    N18 Z2.
    N19 G1 Z-2.98 F222.817
    N20 Y55.998 F668.451
    N21 X3. Y57.2 F1336.902
    N22 Y-7.2 F668.451
    N23 X9. F1336.902
    N24 Y57.2 F668.451
    N25 X15. Y55.592 F1336.902
    N26 Y-5.592 F668.451
    N27 G0 Z10.
    N28 G91 G10 L2 P1 X-0. Y-75. Z0.
    N29 G90
    N30 #21 = #21 + 1
    N31 END 1
    N32 G91 G10 L2 P1 X-0. Y150. Z0.
    N33 G90
    N34 M9
    N35 M5
    N36 G53 Z0
    N37 G53 Y-1 X0
    N38 M30
  8. #68
    Aug 2005
    13
    Jailbreak,
    I already solved the problem by set loop_exist = "N" in the PRP file
  9. #69
    Dec 2010
    32
    Good to know
  10. #70
    Aug 2013
    189
    I've been working with jailbreaker on his Post Processor and so far it's very good, I'm using it to make my latest parts and it works very well. soon as I can I'll make a 4axis index and simultaneous machining test part and make a video so you guys can see it working
  11. #71
    Aug 2013
    189
    cutting some wraped text/pockets around Y cylinder using jailbreaker PP:
  12. #72
    Dec 2010
    32
    Yeah ! Great, Thanks !
  13. #73
    Sep 2006
    8
    Hi folks, need help wit SolidCam 4 axis toolpath.
    I can not do SolidCAM generate the code for the model attached, it simply ignores the part of the model in which the tool you need beyond the center in the model
  14. #74
    Dec 2010
    32
    sdougm, elaborate. I don't get what your problem is.
  15. #75
    Sep 2006
    8
    Take a look in the picture below...
    Why solidcam ignore part inside of redline?
  16. #76
    Sep 2006
    8
    Take alook in picture below
  17. #77
    Dec 2010
    32
    Upload the SW file somewhere and PM me the location. I honestly have no idea what you may be doing wrong.
  18. #78
    Sep 2006
    8
    Quote Originally Posted by jailbreaker View Post
    Here is the SW file link
    https://drive.google.com/file/d/0Bx0...ew?usp=sharing
  19. #79
    Dec 2010
    32
    That's from a future version and I cannot open it on the version I have access to (2014)... I'm guessing you are on your own....
  20. #80
    Sep 2006
    8
    Upload STL file now
    https://drive.google.com/folderview?...Wc&usp=sharing
Page 4 of 6 23456
  1. Postprocessor Camworks to Mach 3
    By mazaracing in forum CamWorks
    Last Post: 02-11-2011, 10:29 PM
  2. 5th axis kinda
    By Delw in forum Haas Mills
    Last Post: 12-14-2010, 03:37 PM
  3. Mach 3 Postprocessor for SolidCam
    By Debos in forum Screen Layouts, Post Processors & Misc
    Last Post: 06-20-2008, 11:15 PM
  4. 2UVR x-axis powerfeed sorta kinda working
    By Stinson_Voyager in forum Tree
    Last Post: 01-14-2007, 08:11 PM
  5. 2UVR x-axis powerfeed sorta kinda working
    Last Post: 12-27-2006, 06:10 PM
