588,338 active members*
4,912 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Share Your Files Part or Art
Page 427 of 587 327377417425426427428429437477527
Results 8,521 to 8,540 of 11734
  1. #8521
    Feb 2012
    20
    qsacracer hope this works out for you.
    Safe machining
  2. #8522
    Feb 2012
    20
    might help if i attached the file. dxf format
    Attached Files Attached Files
    Safe machining
  3. #8523
    Apr 2007
    230
    From the dept. of redundancy dept.
    Just finished this, a bit late I see.
  4. #8524
    Nov 2004
    56
    Perfect, thanks guys
  5. #8525
    Sep 2011
    281
    Quote Originally Posted by graffix11 View Post
    The wood burned image has been altered slightly to be more proportional and supplied in a dxf file. Id like to make some plaques and hope chest or something with it. I have aspire but Im still quite new to it. Any help I can get would be great.
    Thanks ahead, John
    Too many open vectors in that DXF file. It requires some major cleanup.
    Colten Edwards http://www.cncsigns.ca
  6. #8526
    Apr 2012
    11
    It will be a challenge none the less. I'm getting good results with aspire with the node edit mode. Creating seperate components. Im going to continue and use my final version that way its more personal. Ill upload a pic when I get it finished.
  7. #8527
    2010
    Just sharing an image of my latest little project on the chance that it might inspire someone.
    “ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
  8. #8528
    Oct 2011
    69
    Hey jhowelb how did you color your image on the wood and how did you do it
  9. #8529
    Dec 2007
    4
    Here is a wood sign I did for a charity benefit. It took longer than I wanted to spend on it, but it looked nice.
  10. #8530
    2010
    Quote Originally Posted by DJNPHOTO View Post
    I V-Carved the image into MDF and sprayed stencil ink into the pattern then sanded off the over spray.
  11. #8531
    Dec 2006
    137
    Locking device Advice needed?
    This is a different type of request for ideas or links for what i need or drawings.
    What i want to do is make a jewelry box lid and have a 3d carving (as a seperate piece) in the center of the lid. It would have a dowel in the center of it connected to a hole underneath it.
    That would be connected to some type of latch device that would operate similar to a doorknob that would engage or disengage to allow the box to be opened. Just think of a regular doorknob with a longer latch on it. I hope the pictures illustrate what i'm trying to describe. The domed shape represents the 3d carving that would sit on the face of the lid and to open the box you would turn the carving one way or the other. Thanks for your help!
  12. #8532
    Feb 2007
    4553
    myxpykalix,
    Use a hidden rod latch, see attached image.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  13. #8533
    Dec 2006
    137
    Thanks Jeff that is similar to what i had drawn up, since you have a picture do you have a link for where i could buy something like that? I will google that also
  14. #8534
    Feb 2007
    4553
    myxpykalix,
    I would go to the hobby store that sells R.C. plane parts. Pick up a bell crank and a few push rods or a piece of control rod and bend them yourself. Add a few springs to the contraption and your done.
    Jeff...
  15. #8535
    Oct 2005
    90
    Can any of you convert .ttf font files to .shx?
  16. #8536
    Aug 2011
    617
    what's .SHX ?
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
  17. #8537
    Dec 2006
    137
    Hey Jalessi!
    I went down to my local RC shop and of course they had nothing like what i needed. Do you have any links for that part you showed me? Or a distributor name? You got the picture from where?
  18. #8538
    Feb 2007
    4553
    Quote Originally Posted by myxpykalix View Post
    Hey Jalessi!
    myxpykalix,
    Great Planes has what ever you want.
    Great Planes® Model Parts & Accessories - Control Linkages
    Jeff...
  19. #8539
    Feb 2007
    4553
    Post
    myxpykalix,
    Also go to eBay and do a search for "servo arm" you will find thousands of parts.
    Jeff...
  20. #8540
    Dec 2006
    137
    Jeff,
    It helps when you know the right term to search for...thanks. I found this one thing that looks almost perfect but i can't find any local distributors or good measurements on this...:violin:
  1. Share your 3D Carving files, Parts or Art
    By yohudi in forum WoodWorking Topics
    Last Post: 11-17-2016, 08:42 PM
  2. Lada
    By multiple in forum MetalWork Discussion
    Last Post: 01-18-2014, 11:00 AM
  3. Lets Share!!!!! (cut files)
    By Dustin407 in forum Waterjet General Topics
    Last Post: 08-24-2011, 11:46 PM
