588,444 active members*
5,295 visitors online*
Page 43 of 51 334142434445
Results 841 to 860 of 1007
  1. #841
    Nov 2016
    5
    Re: DIY- CNC Embroidery Machine
    Attachment 341184
    hi khalid the procesador of computer is diferent is good calculate screem but controlator is very fast to embroidery...
    in BOLIVIA sudamerica there are embroidery nacional the persons user the machine only needle to manufacture embroiderys of only needle
    firts machine is with computer and programer in DOS but this is low in rpm
    secunds machina is only with controlator how arduino thi is very fast 1000rpm maximo
    sorry for my english my lengua is spanish
    i am can help in the machies embroidery i know funtionin and parts mechanical please agreme my face is giomar oscar arestegui torres
  2. #842
    Oct 2005
    255
    Quote Originally Posted by giomar View Post
    Attachment 341184
    Hi. If english is not your mother language we can always use google translate. Here I copy and past both english and spanish.
    Hola. Si el inglés no es tu idioma materno siempre podemos usar google translate. Aquí copiamos y pasamos el inglés y el español..
    Regards
    Paul
  3. #843
    Nov 2016
    5
    Attachment 341400
    HI DEAR KHALID
    1 ROTARY SENSOR OF THREAD: this one detects the thread rupture exists 2 modes
    First optical mode with a wheel with holes
    Second way is to close a circuit
    2 SELENOID; Is activated to turn off the head. In case of thread breakage and back the machine.
    3 WIPER EMBROIDERY: pick up the thread when the machine cuts
    4 PICKER: Detect the bobbin to make a knot to cut thread.
    The 1 and 2 are 2 electronic signals per head if they would be 10 heads would be 20 independent signals
    The 3 and 4 always work so the heads are off. Is good for not having many electronic signals.
    KHALID IF YOU NEED MORE PLEASE chating for my facebook giomar oscar arestegui torres
    Your job is beautiful
  4. #844
    Apr 2006
    3498
    What help u need giomar?
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  5. #845
    Nov 2016
    5
    Attachment 342694
    please help install
    this is error
    i have win 10 and visual basic please i need your help Khalid
  6. #846
    Приветствую всех кто развил эту тему и добился результатов!! Ребята, присоединяюсь к вопросу, где можно взять рабочую версию Gcode Generator Embroidery? Я не смог найти рабочую версию, смотрел везде уже. Спасибо!
  7. #847
    Dec 2016
    7
    Hey,
    Here is the latest version Khalid posted on the forum earlier. I attached the setup and the latest version (you need to replace the .exe)
    Hope it'll work for you!
  8. #848
    Hello!! Thank you very much! I've been looking for. I think I could use that. Wanted to collect stanochek based on the Linuxcnc gcode, now I want to try first this program. Will try to write about the results when they are! Would make a great machine.
  9. #849
    Sorry, something went wrong
  10. #850
    Dec 2016
    7
    Well, in this zip you have every .CAB to put in the same folder as the SETUP.exe try if it works
    Attached Files Attached Files
  11. #851
    The case moved on, but something still wrongAttachment 343814
  12. #852
    Dec 2016
    7
    I didn't have this problem, try with this setup.exe (I actually have two different setup.exe on my computer for this software). You need to put .CAB in the same folder as setup.exe
  13. #853
    With your permitions has done as it is said, only afterwards file .exe in file it is necessary to change.
    For that to whom too it is necessary will, for the future.
    https://yadi.sk/d/7pQOiaOx34AkVE
  14. #854
    Dec 2016
    7
    Hello,
    Did someone tried GRBL on his Arduino or what kind of program are you running on it?
  15. #855
    Jan 2015
    4
    hello all
    I have installed Embroidery Gcode generator but i am facing an issue while saving Gcode.Click image for larger version.
  16. #856
    Dec 2016
    7
    Hello,
    Try replacing your .exe with the 2.4.8 version in the previous page and retry
    Otherwise you can click on "Populate" button on the right and copy the generated GCode on textarea
  17. #857
    Apr 2006
    3498
    Singh,
    Did u resolve the problem?
    Did you installed Microsoft Access on your computer?
  18. #858
    Prompt assignment of codes with the letters G, M, F, please.
    And why Z adds the value of ten(can be set from 1-20) - what is this option is not clear.
    Created a couple of paths in g-code
    A video of the process, maybe someone in the future will be interesting
    https://youtu.be/YUkPToI5hK0
    files https://drive.google...eTBseV84ajZFRHM
    Dear Khalid, with your permission, I will post the link to the program I have it working, all you had done, you only need to replace the file .exe in the root program.
    https://yadi.sk/d/66j5Z8DM34PHUm
    I offer You my sincere respect and honor for the work you real good, thank you very much, I hope it will be useful.
  19. #859
    Jan 2015
    4
    Hello
    @Khalid, I have installed Microsoft Access Runtime 2010 still not working and same message while using populate button.
    Regards
    Dilraj
  20. #860
    Dec 2016
    7
    Try removing it and reinstalling it with den_sibirskiy files just above
    Let's keep us updated
  1. Embroidery machines
    By Karl_T in forum CamSoft Products
    Last Post: 06-03-2016, 06:54 PM
  2. DIY Embroidery
    By infomatrix in forum DIY CNC Router Table Machines
    Last Post: 06-22-2013, 09:46 AM
  3. Replies: 1
    Last Post: 07-06-2010, 08:48 AM
