The build has started!!!
My pup needed to strach his head with all the different parts lol
So one quick gripe about the leveling feet and no washers on connections
This machine for any business is a capital investment and in doing so you want to get top quality parts for your money within a certain budget and if it costs you a little extra in the total price you should defiantly go for it that being said I like the steel leg kit it is heavy gauge galvanized steel tubing but at all the tube connections you are using a single socket button head allen bolt into steel bracket now I am not an engineer but I am a Certified class A Caterpiller technician and have degrees in diesel technology so I am mechanically inclined and have college level training in areas pertaining to design and function of components
I would like to see a slightly longer Socket Cap allen bolt with a washer for the steel to steel connection or simply a full thread serrated flange bolt and I realize that these are not spinning components but I would like to see them supplied with blue 242 loctite as well
I have always been taught that steel on steel = washer cast iron on cast iron= no washer
So you have this nice heavy frame and it is all supported by 6 plastic leveling feet and the feet along with the connection inside the tube are also plastic within the housing with I believe a brass threaded insert. The thread on the leveling feet is m16 which is nice and big.
What worries me the most is the plastic ball and socket on the actual foot I see this as the weak point in the design. So I think I would have liked to see an all steel construction on the leveling feet. just for piece of mind and long term rigidity I know that once the machine is put in place it will not move but for people like me that will be changing shops in the future the machine could get moved 3-4 or more times and accidents happen plus alot of these machines are in industrial settings and per example what happens if you spill a corrosive liquid on the ground is it going to eat through my feet in a hurry?
These are all just my opinion and take with a grain of salt this is in no way a bash on CNC ROUTER PARTS everything looks well designed and will probably last I am just the kinda person that is always trying to further improve a design so I enjoy making suggestions
Onward and Forward with the build!!
