603,942 active members*
3,727 visitors online*
Page 5 of 8 34567
Results 81 to 100 of 155
  1. #81
    Aug 2011
    215
    Having lots of fun with the machine working again. I'll try not to allow any tool crashes anymore.
    I got my manual written G-code verified tested and working to cut pockets in my electronics doors in order to mount cooling fans. Now I just need to cut the actual doors instead of scrap wood.
    My dad is in town and I showed off the machine to him today. I engraved his name on the back of his cell phone for him. Now he's got a souvenir to take back home
    I also dropped $175 and purchased a license for Mach 3. I like the software a lot and know I'll be using it for a long time to come.
    I'm still anxious to get my feet wet with CAM. I still have never done anything in CAM, other than look at a million websites and tutorial videos. I think I'll try out CamBam as it looks like it has the most bang for the buck (cheap buck too!) at the moment. Anybody happy with other low cost CAMs? The majority of my stuff will be 2.5D stuff, but I do have the need to make 3D molds every now and then for composite fabrication.
    I'm also interested in a good (and cheap) engraving program. I'd like to be able to choose pretty much any Windows font, and especially interested in engraving in several languages. Suggestions?
  2. #82
    Jul 2003
    281
    Quote Originally Posted by GTFreeFlyer View Post
    You did a great job on your project. I have a site you can look at.
    CNC Programming Software Tools
    Here's a good free engraving program too
    DeskNC
    Keep up the excellent work.
    Cheers
    Bob A
  3. #83
    Aug 2011
    215
    A picture of the painted metal parts. Parts lack paint where faces mate with each other so that I have electrical continuity between all pieces.
  4. #84
    Jul 2012
    159
    Nice job
  5. #85
    Dec 2006
    202
    Looks like Bob A. beat me to it with the link to DeskEngrave, which converts TrueType fonts to dxf. I've found that it works better with some fonts than others. Some end up quite jagged if you zoom in on them. Many CAD programs will also bring fonts in as lines. I use Rhino, which turns fonts into beautifully smooth NURBS curves. It will also create surfaces and solid geometry from fonts.
    If you're looking for relatively inexpensive CAM software, I kind of like MeshCam, which has decent basic 3d capabilities: MeshCAM - CNC Software - CAD/CAM Software
    For some simple 2.5d work, I've used Phlatscript, which is a free plug-in for SketchUp.
    -Bob
  6. #86
    Aug 2011
    215
    Doh!
    Not sure why this happened. Plywood, 60ipm, I ramped down into the material right to left as shown to .06" depth using 1/8" carbide up cut 2 flute at 30000 rpm. Which one of these settings was wrong? I had been cutting with 1/4" bit successfully at .1" depth at 100ipm and other settings the same as above.
    Broken bit (the tip sheared off) stuck into the wood and the spindle kept moving to the left and tilted the shank as shown, destroying my new Elaire collet in the process.
  7. #87
    Aug 2011
    215
    On a more positive note, the cutouts for my cooling fans worked out great!
  8. #88
    Aug 2011
    215
    I looked at my broken bit scenario and evidence again this morning. Here's what I found for my failure analysis...
    The bit ramped down into the material travelling right to left as expected until it hit its target depth of .06. It then continued a short distance towards the left without any z-axis movement, as expected. Then all of a sudden the depth increased more with a terrible surface finish on the sides and bottom of the groove, to as much as .13 depth.
    The bit was an up-cut design, so as it travelled in the wood it tried to pull itself down into the material, which is what appears to have happened, possibly from slippage in the collet. The collet was being used for the very first time, so I can not comment on whether or not the collet was good to begin with. I did tighten it sufficiently before use.
    The cutting bit had approximately a 1/8" or slightly longer cutting edge, so once the bit reached this depth in the material, it was no longer able to travel to the left, which is why it pried the collet open as it bent over.
  9. #89
    Aug 2011
    215
    Here is one of three switch panels shown with three of the four switches installed.
  10. #90
    Aug 2011
    215
    Here's a video of me cutting a sq. pocket for the cooling fan.
    Momus CNC cutting square pocket - YouTube
  11. #91
    Aug 2011
    215
    Making more switch panels.
    Momus CNC making a switch panel - YouTube
  12. #92
    Aug 2011
    215
    All done with the panels.
  13. #93
    Aug 2011
    215
    A closer look...
  14. #94
    Aug 2011
    215
    Today I played around with axis speeds and accelerations. I had previously set up my motion to be nice and slow and smooth, fearing I would lose steps. I had my x and y axes set up at 600 ipm and accel of 20. I didn't need much faster, as I had the time to wait 1 second for the spindle to move from one end to the other.
    I got curious to see how fast I could go without losing steps. I wrote a quick g-code program that just jogged the machine left to right over and over again. At each end I would touch the stock material with a v-bit to mark the position. I repeated later for front to back.
    I ended up getting my speed/accel to 1200/75 on the x axis and 1000/60 on the y axis before I started getting scared. This was DEFINITELY fast enough and I never lost any steps with the motors. I don't know why I need it this fast, but I'm leaving it like this now for the cool factor
    I'm using a 1-start screw on my z, so I only get 75ipm on that axis. I can live with that because I like the 1/20,000 steps/per inch resolution.
    I'm curious to know what other Momus owners are using for their settings. Please share.
  15. #95
    May 2011
    24
    Can you post a video of those speeds? I would love to see that.
    I haven't completely aligned and tuned everything yet, but the best I've been able to get so far without losing steps is about 300 ipm. And that is without the weight of the router attached.
  16. #96
    Aug 2011
    215
    I'll grab some video for you next time I have a chance to sit down and play with it. You can send me your own gcode if you want to
  17. #97
    Aug 2011
    215
    Alright here is the video.
    Momus CNC speed test - YouTube
  18. #98
    Aug 2011
    215
    Here is the front AC power panel I finished today.
    I also got my lasers in the mail today. These will paint two lines that will intersect underneath the spindle for quick alignment.
  19. #99
    Aug 2011
    215
    I was trying to work out some math to see how high I can increase my acceleration to and this is what I got:
    Motor torque is 380 oz-in
    Belt pulley is .2 pitch, 10 tooth which yields an effective diameter of .637 inch
    Effective radius is half of that, .318 inch
    Torque = force x radius, which yields that force = 1195 oz, which equals ~75 lbs.
    This means I should be able to pull on the belt with 75 pounds of force before the stepper loses its grip.
    Now we need to find out what sort of acceleration requires 75 lbs of force. This comes from F=ma.
    Rewrite as a=F/m.
    Since m=W/g, rewrite once again as a=Fg/W.
    We will use the worst case scenario and calculate for the y-axis motor, which must move the entire gantry.
    I never weighed it, but I'll assume it weighs 20 lbs with the router.
    Now plug and chug, we get a= 75lbs * 32.2ft/s^2 / 20lbs
    And this yields a=120.75 ft/sec^2
    ...which equals 1449 ips^2 !!!!!
    I increased from 20 ips^2 to 75ips^2, which means I'm still running my CNC machine like a grandma unless I've done my math wrong.
    So who's going to try 1449 ips^2 and let me know how it goes?
  20. #100
    Aug 2011
    215
Page 5 of 8 34567
  1. just another 45 build thread
    By CS900 in forum Benchtop Machines
    Last Post: 03-28-2016, 02:47 PM
  2. Build Thread - 80/20 5X10 Woodworking CNC Build
    By jsantos in forum CNC Wood Router Project Log
    Last Post: 08-20-2014, 03:15 AM
  3. Hi From Jonathan Fortin, Next Engineering inc.
    By next eng. in forum Community Club House
    Last Post: 05-18-2013, 11:39 AM
  4. Build Thread 1
    By groswald in forum Momus Design CNC plans
    Last Post: 11-11-2011, 07:09 PM
  5. Mint's Build Aluminum/Steel Build thread.
    By FreshMint in forum Maintenance DIY Discussion
    Last Post: 10-31-2011, 04:18 AM
