![Quote](images/misc/quote_icon.png)
Originally Posted by
Fatboy
Congratulations on getting your machine up and running!!! Now on to learning to make it do as you wish. Sometimes it seems like the machine or software has a mind of it's own but I know from experience that most of the time it's doing exactly as commanded. It's possible that the moves that your machine is making are actually part of the g-code. To that end, post the code so we can take a look.
The first thing that I learned was that Lazy Cam only makes learning a lot harder. Once I switched to Cut2d I was able to advance at a much faster rate and do things with my machine that others were doing with theirs.
I only wish that I would have had the money to go with V-Carve. Plus I started right off with Mach 3 after playing with TurboCNC and Kcam before even completing my first machine in Jan 2009.
Setting up soft limits are a good idea for your machine even after you get the limit switches installed. There's a lot of people who only use soft limits and have good results. Also, it's a good bet that even if you max out an axis that you'll only lose steps when the steppers are unable to advance.
Edit
I just read your edit ahhh!!! Grasshopper whants to learn how to zero the machine?
My machine is still in my shed and I haven't run it since leaving there in July. Plus next week I'm moving to my property in NC and don't have a place to set up as yet for the near future. I'm worried about forgetting the things that I've learned and having to start over when I can finally find a place and the money to enjoy my machine again. At least I have my shop computer set up and I can play with the programs.
BTW, what is the diameter of your test design? I can run it through Cut2d and send you the code if you like. I'll need feeds(30ipm), speeds(n/a), and tool(pen).
EDIT: I ran your DXF in Cut2d and it appears that the center of the design is located at X16.8502" Y28.5909" so if you zero the machine and then run the code you generated the first thing that will happen is that the machine will move to the location of the design. I find that it's easier to use the center. Also, I can create a profile cut code but there are open vectors that will not cut. Let me play with it, I'm a little rusty.
Fatboy
