588,555 active members*
4,744 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > how to use vfd for old cnc mill
Page 6 of 6 456
Results 101 to 111 of 111
  1. #101
    Dec 2013
    5722
    Re: how to use vfd for old cnc mill
    Yes. Keep in mind that is not an earth or safety GND. It is a common (or also called Return) for the VFD control circuit and should not be connected to an earth ground. I wish the manufacturers would properly label that common terminal, it should not be labeled GND.
    Jim Dawson
    Sandy, Oregon, USA
  2. #102
    Apr 2012
    63
    ok, no worries, so i just need to run a wire from fwd&rev down to the contactor or relay and then on the other side of that relay take a wire back to the GND (common) pin of the VFD.
  3. #103
    Dec 2013
    5722
    Yup, that's all there is to it.
    Jim Dawson
    Sandy, Oregon, USA
  4. #104
    15362
    Quote Originally Posted by jaysihn View Post
    No that is not correct you could not use the contactor to switch this it would be to harsh
    And for the wiring the Relay basically is just a switch ( 1 ) side you connect to FWD the other Side to DCM and the same for the Reverse it is best to use a solid state Relay then you won't have any noise with the switching to worry about
    Mactec54
  5. #105
    15362
    so put 10V output from the VFD to one side of the contactor and then the other side of a contactor back to teh fwd or rev pin of the vfd? I wasn't as comfortable with that just because there are still a variety of other wires going to those contactors that i didn't want to risk screwing up. I figured a couple of DC/DC relays would be safer and cleaner.
    Any reason not to use the dc/dc relay option if I want to?
    No you should not be using the 10v output from the VFD Drive for anything other than to supply for a PWM to analog Breakout board 0-10v supply
    2 Relays is all you need that are controlled by M3 M4
    Mactec54
  6. #106
    Aug 2009
    1573
    so i did some digging to find the wires that correspond to spindle fwd and spindle rev coming from the cnc controller. i found pins 61 and 64 which seem to be 24V logic pins. they go into some relays which have 120V output that feed the main contactors..
    ...these relays look like Solid State Relays (SSR) already installed from factory. photos worth a thousand words
    Attachment 445472
  7. #107
    24221
    Quote Originally Posted by machinehop5 View Post
    Opto22 I/O modules, AC output, maybe.
    Al.
    Albert E.
  8. #108
    Aug 2009
    1573
    Al.
    ...bingo. I think you nailed it. http://documents.opto22.com/0510_Std...data_sheet.pdf
  9. #109
    Apr 2012
    63
    Ya those are ac output. They have 20 something vdc on one side and 120v ac on the other side. I wired it up with the contactors as the switches to pull the fwd and rev pins to the gnd/common of the vfd. Works perfectly at this point...
  10. #110
    Dec 2013
    5722
    Sounds like you're making progress. :banana:
    Jim Dawson
    Sandy, Oregon, USA
  11. #111
    Aug 2009
    1573
    ...its all jaysihn's default for saving the Lagun250....
Page 6 of 6 456
  1. Replies: 2
    Last Post: 05-16-2016, 01:08 AM
  2. Replies: 0
    Last Post: 04-01-2016, 07:54 PM
  3. Replies: 0
    Last Post: 03-27-2016, 04:52 PM
  4. Replies: 0
    Last Post: 02-13-2016, 04:47 PM
  5. How to drill and face mill using table type horizontal boring mill
    By SatishNaik in forum News Announcements
    Last Post: 10-09-2013, 01:10 PM
