588,197 active members*
4,519 visitors online*
Thread: Hoss's G0704
Page 61 of 344 1151596061626371111161
Results 1,201 to 1,220 of 6871
  1. #1201
    Jun 2004
    822
    [Removed]
  2. #1202
    Good luck with the internal intermediate plastic gear holding up.
    That was one of the purposes for my belt drive, eliminating that time bomb.
    My stock radials have been fine to over 7000 rpm but my mill has been comfortable in a 70 degree bedroom
    not tortured running in subfreezing temps below recommended specs.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  3. #1203
    Feb 2011
    110
    PC
    This is the PC I am going to get. It has alot of good revues on it.
    Hotcoat Deluxe Powder Coat Kit
  4. #1204
    Well as long as the mill is still somewhat disassembled, thought I might as well
    kill 4 birds with one stone before I put it back together.
    I'll be extending the Y travel to 9.25 - 9.5 inches.
    The X already has enough travel and any extending would just be a flimsy waste of time.
    I'll be mounting the Y motor in the rear.
    I'll be adding a 5th axis to the head and gaining a couple more inches Z travel.
    Oh yeah, then finishing the oiling system.
    The fun with the lathe/4th axis will have to wait.
    Details will follow when they are done.
    Time to put the ZX45 to work.
    Hoss
  5. #1205
    Feb 2010
    3447
    Quote Originally Posted by hoss2006 View Post
    Hoss
    5th axis!!!!!!!!!!!
  6. #1206
    Jun 2004
    822
    Yeah, it isn't the long term plan since it won't let me get to the 7K RPMs I want anyway. Maybe when I replace the sleeve bearings I will do the quill belt drive conversion.
    Hoss
    (nuts) Maybe I should move it into my living room. The X2 has similar bearings and I have used it for many years in the same environment.
  7. #1207
    Maybe you should, similar isn't the same.
    Hoss
  8. #1208
    Jun 2004
    822
    No, but similar is similar? It just isn't an option. It is where it is and thats where it will stay until I become rich.
  9. #1209
    Is there some particular reason you posted that video here in the first place instead of your thread?
    If you don't like my suggestions, don't post here.
    Hoss
  10. #1210
    Jun 2004
    822
    Don't get touchy. I was just showing an alternate setup - I see this as the most all encompassing thread. And it wasn't that I don't think your suggestion is good, it just isn't an option for me. Back to 'your' thread Hoss.
  11. #1211
    Thanks.
  12. #1212
    Waste not want not, the old Z axis belt drive parts will find a new home on the rear mounted Y axis.
    Will be easier to fit in the enclosure.
    Hoss
  13. #1213
    Well that's easy, found the sketches I made May 2010 for the Y extension already, forget
    sometimes that I draw these things up.
    My packratitis makes up for senility.
    Hoss
  14. #1214
    Oct 2007
    7
    Hoss
    Hoss,
    Long time lurker here wants to thank you for all you have given to the group.
    I have no idea how you find the time to get all this done but I am amazed at the pace you manage to keep developing new mods.
    I have been debating on getting a G0704 because the Y travel is a bit to short for the project I have in mind without having to reposition the part so I am really looking forward to this new mod.
    Neal
  15. #1215
    Nov 2009
    4415
    Quote Originally Posted by Neal IN View Post
    Hoss,
    Neal
    Neal, Judging from the time he is posting he must be getting help! 3:08am? Night owl would be an understatement! It is fun to see what he is up to next. I am waiting on a G0704 and his build as a few others have definitely fed the desire.
    A lazy man does it twice.
  16. #1216
    yep, a nightowl, I'm usually up till 6-7 am before hitting the hay.
    I drew up the prints last night (this morning I guess) so now I gotta go make some parts.
    I'll be using the ZX45 to open up the base but it could be done with a drill and grinder if needed.
    Nothing critical to do to it just get some cast iron out of the way.
    Needs a longer ballscrew, I could use the one there now in the front but would only get about 8.5 inches of travel.
    Needs a much different one to go in the rear.
    well, time for some breakfast.
    Hoss
  17. #1217
    Well after drawing up 4 different scenarios for extending the Y axis, particularly in mounting of the stepper,
    I've settled on one that requires the least amount of mods to the base and column,
    those would be the most difficult parts to rework.
    Right now they just need a 1 inch clearance hole and the slot opened up.
    Could very well be done with hand tools.
    The precise bits are left for the bracketry which is much easier to handle and machine.
    I'm doing a front stepper mount first since I can use a ballscrew from the X2 X axis to get it back up and running
    and use the g0704 to make the parts for the rear mount.
    Hoss
  18. #1218
    Feb 2010
    3447
    Hoss
    I'm like Hoss, i'm always am up till 5-6.
  19. #1219
    Quote Originally Posted by diyengineer View Post
    Here's more proof.
    Since I've been off work and on pain meds, my hours are even more screwy.
    Just came up from the basement with these parts.
    The column spacer and the base with the slots opened up.
    Went 1.25 more on each end.
    The rear is 1.75 deep, was quicker to plunge out most of the material
    then give it a couple go rounds to pretty it up.
    I used my 1/2 inch drill to put in the 1 inch holes, should have set it up on the drill press.
    My finger is pretty sore.
    Hoss
    Attached Thumbnails Attached Thumbnails 031311 008_800x600.jpg   031311 016_800x600.jpg   031311 018_800x600.jpg
  20. #1220
    Feb 2010
    3447
    Here's more proof.
    Hoss
    Geez! Pretty sweet! After this mod what will your total travel be?
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
