603,774 active members*
5,153 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
Page 66 of 91 1656646566676876
Results 1,301 to 1,320 of 1805
  1. #1301
    Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
    G-Code question?
    I have code which starts in the center at x0 y0, and spirals outward. Then it moves inward 1.0 inch and is finished.
    The problem is in MACH3, as when I go to Manual Input tab, nothing I enter will work and I get an error message in the status line stating there is a missing component to the G3 R commands!
    MACH3 must be shut down & reloaded to get anything else done!!
    Can anyone help?
    (16.5 spirial pocket .025 deep)
    F450
    G0 X0 Y0
    G0 Z0.5
    G01 Z-0.0250
    G3 Y0 X0.25 R0.125 F450
    Y0 X-0.25 R0.25
    Y0 X0.5 R0.375
    Y0 X-0.5 R0.5
    Y0 X0.75 R0.625
    Y0 X-0.75 R0.75
    Y0 X1 R0.875
    Y0 X-1 R1
    Y0 X1.25 R1.125
    Y0 X-1.25 R1.25
    Y0 X1.5 R1.375
    Y0 X-1.5 R1.5
    Y0 X1.75 R1.625
    Y0 X-1.75 R1.75
    Y0 X2 R1.875
    Y0 X-2 R2
    Y0 X2.25 R2.125
    Y0 X-2.25 R2.25
    Y0 X2.5 R2.375
    Y0 X-2.5 R2.5
    Y0 X2.75 R2.625
    Y0 X-2.75 R2.75
    Y0 X3 R2.875
    Y0 X-3 R3
    Y0 X3.25 R3.125
    Y0 X-3.25 R3.25
    Y0 X3.5 R3.375
    Y0 X-3.5 R3.5
    Y0 X3.75 R3.625
    Y0 X-3.75 R3.75
    Y0 X4 R3.875
    Y0 X-4 R4
    Y0 X4.25 R4.125
    Y0 X-4.25 R4.25
    Y0 X4.5 R4.375
    Y0 X-4.5 R4.5
    Y0 X4.75 R4.625
    Y0 X-4.75 R4.75
    Y0 X5 R4.875
    Y0 X-5 R5
    Y0 X5.25 R5.125
    Y0 X-5.25 R5.25
    Y0 X5.5 R5.375
    Y0 X-5.5 R5.5
    Y0 X5.75 R5.625
    Y0 X-5.75 R5.75
    Y0 X6 R5.875
    Y0 X-6 R6
    Y0 X6.25 R6.125
    Y0 X-6.25 R6.25
    Y0 X6.5 R6.375
    Y0 X-6.5 R6.5
    Y0 X6.75 R6.625
    Y0 X-6.75 R6.75
    Y0 X7 R6.875
    Y0 X-7 R7
    Y0 X7.25 R7.125
    Y0 X-7.25 R7.25
    Y0 X7.5 R7.375
    Y0 X-7.5 R7.5
    Y0 X7.75 R7.625
    Y0 X-7.75 R7.75
    Y0 X8 R7.875
    Y0 X-8 R8
    X8 Y0 R8
    Y1 X7 R1
    This code was generated by the Circular Pocket wizard !
  2. #1302
    Here is the project I've been working on, the spiral code flattens the top prior to V-Carving the details!
    Source code is in VCarvePro format
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  3. #1303
    35494
    Not sure what you're trying to do with the spiral code and MDI??
    The code loads and runs fine here.
  4. #1304
    Yes Gerry, the code works perfectly! But after its done, if you go to MDI and enter something like X0Y0, Mach3 gives me an error message !
  5. #1305
    Jun 2013
    1041
    You don't have a m30 or any other reset at the end of your program. Since your last g-code was a g3 it is still trying to move in a arc. Try G0 x0 y0 or g1 with a feedrate.
    Ben
  6. #1306
    Its been a while since my last post, so here is an update!
    BIG RED is running like a top, but all attempts to set the spindle's electronic brake failed! So I contacted the seller who told me the circuitry in the VFD inverter has never been installed, that's why it's non responsive😡 Well, it's no big loss, other than the 70 Ohm 300 watt resistor that I paid $14 for !
    So here is a picture of my latest carving on Big Red!
    Is made from a 40" long 2x12 pine plank😇
    6 cutters !
    Happy 4th of July to all!
  7. #1307
    Dec 2004
    1316
    Like it !!!!!!!!!
    What's the total machining time.
    Jason
  8. #1308
    35494
    Quote Originally Posted by widgitmaster View Post
    You probably figured it out, but the error is because Mach3 is still in G03 mode. IN MDI, type G0 or G1 before your X0 Y0.
  9. #1309
    Got it Gerry, thanks!
  10. #1310
    Thanks Jason!
    Run time: 00:33:02
    Here is the VCarve Pro Code for the Man Cave plaque:
  11. #1311
    Here is another fun project!
    This also made from a 2" x 12" x 17" pine board!
    Run time 00:06:38
    Code is in VCarve Pro format!
  12. #1312
    Chinese Zodiac
    This is made from an 18" diam x 1" pine panel from Home Depot!
  13. #1313
    Sep 2011
    281
    Thank you Mr Widget. Looks like some work in my future.
    Colten Edwards http://www.cncsigns.ca
  14. #1314
    Sorry, I didn't mean to Flip Everyone Off
    But the bony fingers are popular around here
  15. #1315
    For months now, I've been trying to make some really cool large plaques! Finding the right material, and keeping it flat on the table is definitely a challenge ! So after many try's, I have a great solution to the problem ! Make a fixture out of MDF and use Oak dowels to pin it to the table. Also, I found threaded brass inserts at ACE hardware. So I wrote a prog to drill holes through the MDF fixture panel and into the table. Then I removed the panel and drilled larger holes in the table. Next I installed the brass inserts and ground the tops off the inserts so they were slightly below the surface.
    Then I cut some short Oak dowels, 1/2" diameter. Then I glued them into the panel leaving enough protruding from the bottom side, to align the panel with the holes in the table! The remaining dowel protruding from the other side, will be cut flush when I mill the fixture surface. Also, I milled G29 on top surface so I know which offset to use for this fixture!
    Because Lowes & Home Depot sell panels with different dimensions, I made a fixture for each vendors panels! Lowes panels are edge glued Aspin, Home Depot sells common pine panels which are thinner & narrower! The Aspin panels are softer, and require newly sharpened cutters or the surface fuzzes up, requiring lots of sanding
    Next I drilled holes in the fixture for 10x more inserts. Now I have to make the clamps, Hard Maple will do the job nicely!
  16. #1316
    Feb 2007
    4550
    Eric,
    Nice picture at the beach, looks like you forgot your swim trunks.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  17. #1317
    Apr 2005
    1271
    Outstanding work Eric! Good to see you posting again!
    The plaques even look great!
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  18. #1318
    This morning I made another plaque out of a 40" long 2x12
    This one was not without problems, as the federate of the large 1 1/4" diam x 90 deg V-Bit was too fast.
    This caused the cutter to snap off
  19. #1319
    This morning I finished up another kool plaque(chair)
    It's made from a 2"x12"x25" long pine board!
    Took 5x different cutters, an about 37-minutes run time!
    Here is the Source File in VCarvePro format!
  20. #1320
    Dec 2007
    2133
    Love it!
    As always, brilliant job!
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  3. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  4. 4-axis CNC-router, NEMA23 steps, Gecko 540, Water cooled spindle
    By Vaffel in forum CNC Wood Router Project Log
    Last Post: 10-18-2010, 08:54 PM
  5. Water cooled spindle need ???
    By BFcarbon in forum Commercial CNC Wood Routers
    Last Post: 03-04-2006, 10:05 PM
