588,655 active members*
5,734 visitors online*
Page 67 of 90 1757656667686977
Results 1,321 to 1,340 of 1793
  1. #1321
    Jan 2007
    467
    Actually, I just added the G540 to the website. It is for sale right now for $299 with the manual up on the site as well. Enjoy!
    Marcus
  2. #1322
    Feb 2007
    592
    Talking And the Crowd Goes wild...
    Quote Originally Posted by Mariss Freimanis View Post
    The G540 is ready and is available for sale starting tomorrow. I have attached the G540 MANUAL.pdf for those who want to look at it.
    Mariss
  3. #1323
    Jul 2007
    48
    You beat your mid aug date. Great news! Way to go!
  4. #1324
    Mariss
    In the manual, it looks like your suggested wiring diagram has two wires switched, pos #6 and #10.
  5. #1325
    Sep 2007
    55
    Mariss, congratulations on getting the G540 out. It appears that the wiring diagram is wrong in respect to the wiring of the E-stop switch. The text says pin 6 and the diagram shows pin 10.
  6. #1326
    Oh jeez.. You are right. That's what happens when I hurry. I'm correcting right now. Thanks.
    Mariss
  7. #1327
    Sep 2006
    1738
    OMG! THE 540! Will be buying this week!!!!!
    -Jason
  8. #1328
    Sep 2007
    55
    In the manual you suggest using a N.O. switch for E-stop. I always thought that an N.C. switch is safer as a broken or loose wire would cause an E-stop. Using a N.O. switch a broken wire will result in E-stop not being available.
  9. #1329
    Jun 2008
    467
    Smile Maybe the $39.00 G251 will ship in a few more days.
    Nice to see you are making progress, maybe the $39.00 G251 will ship in a few more days.
    Let us know if you need a cake for the celebration.
    JoeyB
  10. #1330
    OK, the pdf has been updated.
    Mariss
  11. #1331
    Sep 2006
    1738
    Mariss, love the manual...Very simple and straight forward. Look for a purchase from me at the end of the week! Amazing
    -Jason
  12. #1332
    rgoldner,
    A lot of these issues will be addressed in the next revision. We had to get off the dime and get this sucker out there.:-) We are also looking at providing the 4 mating male solder-cup DB9 connectors and metalized plastic backshells (Digikey 109MEA-ND and 909GME-ND respectively) with each G540. That should make motor cable fabrication easier for users.
    Mariss
  13. #1333
    Sep 2006
    1738
    Oh for sure! But you provided the part number which is great! Thanks!
    -Jason
  14. #1334
    Jan 2008
    32
    In the next revision?
    There was talk about including "Mach3 closed loop spindle control to work" via PWM to an optocoupler. Are you still looking at including this in the next revision of the G540? I'll wait for that if it is going to be included next time round. Thanks again for a great product and sharing the design process.
  15. #1335
    Mar 2007
    122
    Quote Originally Posted by rgoldner View Post
    Hi Guys,
    Could we just use a Inverting Buffer so we can still use the E-Stop as a normally closed switch?
    Just an idea.
    Al
  16. #1336
    Mar 2007
    73
    YEE HAW!!!!:cheers:
    Glad to see your hard work has paid off, Mariss. The only problem I can see is that it will probably be another week before I can afford to get one. Now that it is finally here I will be trying my best to get one as soon as possible though. Can't wait.
    Kenith
  17. #1337
    Nov 2005
    655
    E-mail received, order complete!
    The stork is on it's way with a playpen full of some baby geckos ( forgot the winning name ). oops
    Cheers
    Walking is highly over-rated
  18. #1338
    Sep 2006
    1738
    Mariss, do the metalized plastic backshells cover the connectors? I'm looking at them and am not 100% sure.
    Whats the best PS for the Keling KL23H276-30-8B stepper?
    Will a 48 volt 7.3 amp work well in my situation. Trying too find the equations too figure it out.
    Will be ordering this week!
    -Jason
  19. #1339
    Feb 2007
    4553
    Smile The G540 inputs most likely are passive
    I am guessing that you actually can wire the Estop in normally closed mode.
    The G540 inputs most likely are passive so you just ignore the diagram since its only a suggestion.
    Al suggested a buffer however no additional device is needed.
    Marris can you confirm this?
    Jeff...
  20. #1340
    Jul 2008
    922
    Quote Originally Posted by kiwibum View Post
    any news?
    i also have not been following this thread for about a week, where are people ordering their 540's?
    regards
    edit- right from the d*mn website...
    i fail sorry
  1. Avoid Teknic drives, they are cheap for a reason....
    By ckm in forum Servo Motors / Drives
    Last Post: 06-21-2016, 12:27 AM
  2. Interact Bosch servo drives for cheap!!!!!!
    By Interact77 in forum Bridgeport / Hardinge Mills
    Last Post: 02-02-2010, 12:29 AM
  3. AMC drives
    By ka67_72 in forum Servo Motors / Drives
    Last Post: 03-10-2007, 01:38 PM
  4. Replies: 1
    Last Post: 07-24-2005, 12:31 AM
  5. can you ID these drives
    By SJ781 in forum CNC Machine Related Electronics
    Last Post: 04-28-2004, 03:16 AM
