Blimey. Blindingly obvious when you put it the way you have. Thank you. I should have realised this before because I do actually do something similar already. I have a small clamping board around 1220mm square and 18mm thick which I use for cutting small bits and pieces. I simply place that on top of my spoil board, it's 18mm thick so I put that into my X offset on aux.
Hope you follow
