588,337 active members*
4,660 visitors online*
Page 7 of 8 5678
Results 121 to 140 of 142
  1. #121
    Nov 2005
    98
    Quote Originally Posted by mindstorm88 View Post
    From post 34
    Guys just to clarify , the added bearing is sliding on the lead screw ???? no danger to stick with dust ???
    any reply guys???
    starting to put parts together tonight !!!!
  2. #122
    Dec 2006
    457
    I have additional bearings on both X and Y leads, Y being at the other side of the Z carriage, X being on the other end of the Y carrage box. I believe I was the one who identified to place the extra bearings in place and I have had them in since this machine when into production. So far I have no wiping action no matter how fast it moves and I have not seen and binding or such when using it.
  3. #123
    Aug 2004
    3215
    Buzz, Can you post a picture? Also like to see how your machine is running now since you have so many miles on it now
    joe
  4. #124
    Dec 2006
    457
    You can see pictures at www.cncmachine.phillipsfamily.ca. Pick the 2006 machine and build pictures are under ther. Check out the section Torsion box adjustments just over half way down. I don't have pictures online with the Y axis done but it is the same principle.
  5. #125
    Sep 2007
    6
    Has anyone used a shop vac modified to hold pieces in place on the cutting area. Basically seal up the outer ribs and bottom of the cutting area torsion box and install a connection with a hose adapter for the vac and install peg board substrate. I am sure this has been disussed before.
  6. #126
    Aug 2004
    3215
    Quote Originally Posted by _jms_ View Post
    It has been discussed before, but to my knowledge no one has done it before. I know on some CNC machines people use MDF with the skins removed to allow air passage through the material, its a special named MDF board they use, and allot of people use the Vein Shopvacs which are very good then used with a vacuum table system.
    Joe
  7. #127
    Sep 2007
    6
    The peg board has a melamine coating which should make a nice surface...at least for a while. I think it would be best to secure it with silicon so it would be easy to swap once it gets hit a few times from through cuts.. The vac I have is one of those rigid 6hp deals from HD...I was just hoping someone had tried it before. Might have to post this in a more general cnc forum...
  8. #128
    Sep 2006
    290
    Hitachi speeds
    Here are the speeds recorded by David Da Costa . http://www.cnczone.com/forums/showpo...postcount=1168
    I had to search for them as Joes 2006 is so large, I thought I would post them here for future reference and for those not reading the whole thread .
    Hitachi speed by David Da Costa
    1=8,500
    2=11,500
    3=14,500
    4=17,500
    5=20,500
    6=24,000
  9. #129
    Sep 2007
    21
    Please tell me where can I find the DXF files for JOE 2006.
    Can they be downloaded from somewhere?
    Lucian
    Insanity: doing the same thing over and over again and expecting different results.
    Albert Einstein, (1879 - 1955)
  10. #130
    Aug 2004
    3215
    Quote Originally Posted by artwood_decor View Post
    Lucian
    http://rs134.rapidshare.com/files/13...l_2006_R-2.zip
    Joe
  11. #131
    Sep 2007
    21
    Thank you JOE
    Already saved them...
    that was a lot of work for you to put so many parts together...
    hopefully some day I'll afford to build the 4x4 hybrid
    Lucian
  12. #132
    Sep 2009
    30
    I'm fixing to do some major modifications to the Y and Z gantry and was wondering if there is still a set of plans that was done in Sketchup. I had one and lost it and it sure would be nice to have it again.
  13. #133
    Oct 2006
    143
    I have the SketchUp files. Send me a PM with your email and I will send them to you.
    Dwayne
    Found the original files here http://cnczone.com/forums/showpost.p...&postcount=732
    You can just download them from the link above if you like.
    Never underestimate the power of Stupid People in large groups.
  14. #134
    Sep 2009
    30
    Quote Originally Posted by DayneInfo View Post
    Dwayne
    Thanks D,
    I downloaded the pack from post #130 and all of the versions are there.
    I had the Z axis sliding part done a while ago because with plastic parts and the router being so far out it was giving me too much vibration when cutting aluminum. Here are some pics of it. For cutting wood and doing engraving the original design is perfect for the money.
    The Capture.jpg is a new design made out of steel. I ended up getting all the linear bearings and stainless rods as a freebie so I had to jump on it. The X-axis slider has a dual bearing block and I need to insert another single bearing slider next to it since the Y gantry leg is 9" wide. The bottom horizontal connector between the Y gantry legs is a 2 X 6 steel purlin and the top bridge is the same, 2 purlins split and welded together to make it wider. There will be a 1/4" steel plate welded inside the purlins' ends so that they can be bolted on. The Y gantry legs are 1/4" steel plates and I'm contemplating of having the machine shop mill a 1/8" deep blind hole for the 3/4" horizontal rods, then I can drill, tap, and screw them on.
    I'll post the final drawings when I'm done with it. All of the steel parts can be purchased relatively cheap. A single stock length of a 2 X 6 purling can be used to produce all the parts and with plenty of leftover to even make a new table out of it. I'm getting all of the 1/4" steel plate parts plasma cut by my steel supplier for $35, can't beat that.(flame2). The only critical deal here is the 60" long rod. A 3/4 drill rod will flex up to 1/8" on that length where a stainless will cut that down to a fraction but a simple solution to that would be to place an additional single bearing support running on top of a L-angle below the linear bearings (with some brushes on either side of the bearing in case some trash ends up on the runner).
    Attached Thumbnails Attached Thumbnails dscn1560.jpg   DSCN1563.jpg   DSCN1564.jpg   Capture.JPG
  15. #135
    Nov 2005
    138
    My upgrade so far
    I had intended to wait until I was closer to completion but after seeing some action on this thread I have decided to jump in.
    I have been working on a new gantry for my 2006 which incorporates design elements from Joe's 4x4 as well as mods inspired by other DIY machines, commercial units and some of my own ideas.
    The carriage can run outside of the gantry uprights on both sides to allow for an upcoming 4th axis on one side and a future tool changer rack on the other.
    I will probably start a new thread on this with more information and pics in the near future. I will post a link when I do.
    Attached Thumbnails Attached Thumbnails CIMG0291.jpg   CIMG0292.jpg   CIMG0293.jpg   CIMG0300.jpg
    Mike
    If you can't overbuild it, what's the point?
  16. #136
    Sep 2009
    30
    Hig, that looks promising ,
    Nice concept, but you are still riding on the mdf base, plus you are going 2 foot out. The angle iron support was invented by me, way back, and it does well for wood.
    Besides mdf construction and since you have aluminum extrusions I really want to bring up a fact about the process of machine design. Any production machine is prototyped in aluminum, hopefully not in a 80/20, designers have their own 80/20's, extruded shapes that work better and are much cheaper when you have your own dies. This is where the limits are tested and then the order goes out and usually a company in Holland is willing to make a caste production model for a cost plus the rights to sell. This is a standard, ask Joe; he didn't pop out of the woodwork and invented a wheel, he came up with the decent low budget deal and God bless his Texas soul.
    I'm not saying that you do not have a good idea. It is great. But you have to realize that your spindle will be dancing like cow's piss on a flat rock out there if you decide to push it on some aluminum angle sliders. Just like me with my previous wife.
  17. #137
    Nov 2005
    138
    Hi Serb,
    If I didn't stay with the MDF table this wouldn't be an upgrade it would be a new machine.
    All DIY projects are essentially an exercise in R&D. We try things to see if they will work. When things don't work, we make changes and try again. I can't guarantee that my mods will be successful but I'm hoping they will be. If not I will take that lesson and apply it to the next attempt. It's all in good fun anyway.
    I'm using the same steel angle and bearings as the Joe's 4x4, so I think that part is pretty well proven. It's everything else I need to worry about.
    Mike
  18. #138
    Nov 2005
    138
    Machine build thread
    Here is the link to my new build thread.
    http://www.cnczone.com/forums/showth...030#post693030
    Mike
  19. #139
    Sep 2009
    30
    I finally got the baby done. The linear bearings and rods were a freebie so I can't complain but if I had to purchase them I would go with rods that have continuous support and open linear bearings. The 3/4" rods on the X axis were sagging in the middle due to the weight of the Y gantry so I added a flat bars and installed 2 bearings to ride on it on each leg of the Y gantry. In order for the same bars not to flex along the Y direction while cutting I added a 1/2 X 1/2 U-channels at the bottom of the table and made a guide that rides on it from a UHMW 3/4" material. I had to use the same method w/ 1/2 X 1/2 U-channel and a guide for the Y gantry. The two 3/4" rods did not sag in the middle but they were flexing in the opposite direction of the X travel; when the Z gantry was extended all the way down the top rod was flexing one way and the bottom one was doing the opposite. This is why I wish I had rods w/ continuous support so next time I'll attach a spec sheet to the freebie orders. Another thing I noticed is that there is a little play in the Z slide. I did use 2 linear bearings per rod but the self aligned bearings within the bearing blocks have too much play for my taste so I'll end up replacing them with some linear bushings. On the X rods I have long bearing blocks w/ 2 bearings in it and a single block w/ a bushing on each side and on the Y rods I have long bearing block w/ 2 bearings in it and they work just fine.
    Attached Thumbnails Attached Thumbnails DSCN1800.jpg   DSCN1802.jpg   DSCN1803.jpg   DSCN1807.jpg
  20. #140
    Jan 2011
    19
    What are the most fundamental mods?
    I am planning on building either a joe's cnc or something with a similar footprint. First of all, thanks to Joe and everyone else for allowing me to begin my project so far ahead of anything I could have come up with on my own. I have read this thread and the main joes2006 thread. I still can't easily pinpoint the major weaknesses of the original design and how to correct them. Here are some of my ideas, any comments or additions would be excellent:
    • The supports for the pipe on the x axis seem to allow the pipe, if it is not attached to the u supports, to sag down and out. Would it be better to simply use something similar to the y axis with the supports between the pipes? I am also thinking of filling them with concrete, although, from what I understand, it is a good idea to pass a through bolt down their centers(?).
    • All pipe should be polished.
    • There is a bit of whip in the x axis. It is best to have two spaced bearings at each end along with a tensioning system.
    • Due to backlash, one should stay away from the spider couplings and go with direct couplings. A counterweight damper on the motors is a great addition.
    • It seems that many people like to stiffen up the gantry, either using angle brackets or through bolts, or both. I wonder if there are better options for this, such as cutting two sides to the gantry each out of one piece of mdf.
    • a more advanced type of anti-backlash nut is important.
    Lastly, Has anyone tried using v groove bearings and a rectangular bearing mount, and did it work well?
    Once again, thanks! I am looking forward to your tips, particularly if my list shows that I am not paying attention to something important.
Page 7 of 8 5678
