Andy,
If any bare boards are available, I would be interested in purchasing some. Please send me a PM.
Thank you.
Roger
Andy,
Thank you.
Roger
Hello Andy
If any bare boards are available, I would be interested in purchasing 2.
Thank you.
Inco
Just stumbled on this thread. I have some glentek servo amps with powersupplies and motors that take a 0-10V signal and would like to use them for position control under Mach3 for a hobby project.
Is this the board that does that? Could I get in on some boards if they are being ordered? Is there a parts-components list or source list?
Bill
Hi Bill
Yes these boards will enable you to use your servo's with Mach.
I have only three YAPSC boards left and one of the USBprogkey boards.
For more info and parts list etc first download and install Kicad, go to Max's website and download all the files,you will then be able to look at the layout of the boards and get a parts list.
If you are interested in the last remaining boards send me a PM.
Andy
please give somewhere can I buy yapsc + 10vkonverter
thanks
Hello MAX
Please Help
I have a problem width the compiler V1 code for DC brush motor
MPLAB v8.63
C30 compiler v3.25
Debug build of project `C:\PIC Project\Servo\Servo.mcp' started.
Language tool versions: pic30-as.exe v3.25, pic30-gcc.exe v3.25, pic30-ld.exe v3.25, pic30-ar.exe v3.25
Preprocessor symbol `__DEBUG' is defined.
Thu Feb 24 17:54:46 2011
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "encoder.c" -o"encoder.o" -D__DEBUG -g -Wall
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "main.c" -o"main.o" -D__DEBUG -g -Wall
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "pid.c" -o"pid.o" -D__DEBUG -g -Wall
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "serial.c" -o"serial.o" -D__DEBUG -g -Wall
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "capture.c" -o"capture.o" -D__DEBUG -g -Wall
capture.c: In function '_IC2Interrupt':
capture.c:78: warning: implicit declaration of function 'checkDir'
capture.c: At top level:
capture.c:139: warning: conflicting types for 'checkDir'
capture.c:78: warning: previous implicit declaration of 'checkDir' was here
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "commands.c" -o"commands.o" -D__DEBUG -g -Wall
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "pwm.c" -o"pwm.o" -D__DEBUG -g -Wall
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "test.c" -o"test.o" -D__DEBUG -g -Wall
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "timer1.c" -o"timer1.o" -D__DEBUG -g -Wall
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 "encoder.o" "main.o" "pid.o" "serial.o" "capture.o" "commands.o" "pwm.o" "test.o" "timer1.o" -o"Servo.cof" -Wl,--script="p30f4012.gld",--defsym=__MPLAB_BUILD=1,--defsym=__MPLAB_DEBUG=1,-Map="Servo.map",--report-mem
doprnt_cdfFnopsuxX.o: Link Error: Could not allocate section .data, size = 464 bytes, attributes = data
powers.o: Link Error: Could not allocate section .data, size = 352 bytes, attributes = data
Link Error: Could not allocate data memory
Link step failed.
Debug build of project `C:\PIC Project\Servo\Servo.mcp' failed.
Thu Feb 24 17:54:56 2011
BUILD FAILED
Sorry, the good error message:
Thu Feb 24 18:33:25 2011
Clean: Deleted file "C:\PIC Project\Servo\encoder.o".
Clean: Deleted file "C:\PIC Project\Servo\main.o".
Clean: Deleted file "C:\PIC Project\Servo\pid.o".
Clean: Deleted file "C:\PIC Project\Servo\serial.o".
Clean: Deleted file "C:\PIC Project\Servo\capture.o".
Clean: Deleted file "C:\PIC Project\Servo\commands.o".
Clean: Deleted file "C:\PIC Project\Servo\pwm.o".
Clean: Deleted file "C:\PIC Project\Servo\test.o".
Clean: Deleted file "C:\PIC Project\Servo\timer1.o".
Clean: Done.
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "save-res.c" -o"save-res.o" -D__DEBUG -g -Wall
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 "encoder.o" "main.o" "pid.o" "serial.o" "capture.o" "commands.o" "pwm.o" "test.o" "timer1.o" "save-res.o" -o"Servo.cof" -Wl,--script="p30f4012.gld",--defsym=__MPLAB_BUILD=1,--defsym=__MPLAB_DEBUG=1,-Map="Servo.map",--report-mem
stdclean.o: Link Error: Could not allocate section .data, size = 98 bytes, attributes = data
Link step failed.
Thu Feb 24 18:33:37 2011
BUILD FAILED
someone built it ?
How it works ?
Hello to all!
Can anyone sell me three PCBs of these amazing Project? I would like to bulid 3 of these YAPSC. The shipping is to Germany.
Thank you very much.
M. Bente
Can some body sell me (8 Pc's) DIY YAPSC (4 Pc's) V10 and (4Pc's) V1 and also (2 Pc's) of ProgKey . ,shipping to Syria by FedEx .
[email protected]
I am interested too in YAPSC boards
If any bare boards are available, I would be interested in purchasing tree (3).
The shipping is to Mexico.
Thank you
Hi All
I have had a few requests for the YAPSC 10V bare boards can everyone who is interested please post on this forum how many boards you require of the 10V and if you require the ProgKey board (this is used to tune the servo's through the YAPSC).
So if you have alredy requested boards please post again with your requirements.
I will leave this running until October 31st 2011 after which I will no longer be ordering any more boards so this will be your last chance.
The boards in the past have been $7.50 each plus shipping but this will depend on any price increase since my last order.
Many Thanks
Andy
I ask you how to make an order yapsc 10 pcb board +-10v
greeting
Hello Andy,
I would like to confirm my order : I need three (3) YAPSC 10V bare boards and one (1) of the USBprogkey board. The shipping is to Mexico.
If you need further info, kindly advise.
Thank you.
Ok
I will start the list 18/10/2011
Aluplastvs 10 x YAPSC 10v
FAXed 3 x YAPSC 10v 1 X USBprogkey
bobgerman 6 x YAPSC 10v 2 X USBprogkey
AlexDion 3 x YAPSC 10v
Regards
Andy
Andy,
Tag me for:
(6x) YAPSC 10V
(2X) USBprogkey
If this is still going on pleaseinclude me for:
(3) YAPSC 10V
(1) USB progkey
Thanks.
Ok
Yhe latest list is as follows:-
Kenski 3 X YAPSC 10v 1 X USB progkey
Regards
Andy
Andy,
Sorry but I think I'm going to go another way. The Mesa 7i33 Quad Analog servo interface looks like it'll do the job quite well. Combined with their 5i20 FPGA based PCI Anything I/O card it'll also give me plenty of speed + lots of I/O ports for all those extras down the road. ( http://www.mesanet.com/ )
