588,270 active members*
11,290 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > How to change max rapid speed on Haas TM-1??
Page 7 of 7 567
Results 121 to 128 of 128
  1. #121
    Feb 2010
    Quote Originally Posted by ihavenofish View Post
    ... so basically you added some useless information to confuse the thread even furthur.
    mach has 1000 lines look ahead, more than haas's so called high speed look ahead if im not mistaken.
    most industrial controls these days are very closely related to mach. evan fanuc is running on windows now.
    but none of thats relevant.
    Can stepper motors move that fast?
  2. #122
    Feb 2008
    106
    Quote Originally Posted by MKproto View Post
    Mach3 also supports servos.
  3. #123
    Oct 2006
    669
    Yes, they can. Can you?
    Mach 3 isn't limited to just stepper drivers. But you already knew that, didn't you?
    And it is hilarious that a basically open-source controller software that licenses for $159 is more capable than the controller that comes in a Haas.
  4. #124
    Mar 2009
    48
    So I had to know - what is all the fuss about Mach 3. I went their website and found a wealth of information. The software alone is $175.00. I noticed they have a lot of products. If you want their "CNC Mill Control Analog" it is $4895 This really does not make a whole lotta sense as I know that I can get a Fanuc for around the same price.
  5. #125
    Jun 2007
    3891
    Quote Originally Posted by Xenomorph View Post
    i think youve got the wrong company. the website for mach3 is machsupport.com. the company is artsoft. they dont make any hardware whatsoever.
    and if you can get a comeplete new fanuc control and servo system like the machmotion one for sub $5000, send it my way. i cant even get a single motor for that.
  6. #126
    Mar 2009
    48
    You are right. I was looking at http://www.machmotion.com/product_in...products_id=49
    No - it is not, it is a little bit more and does not include the servo system.
  7. #127
    Jun 2007
    3891
    yeah, but thats the analogue conversion kit. move one notch up the page and youll see a compelte kit for even less.
  8. #128
    Feb 2008
    106
    You don't need that crazy control "system". The software works great right off a PC with readily available controller boards.
    I used an xbox wireless controller as a pendant, and was able to install a touch probe with tool setter for $45.00, yes, $45. Worked fantastic.
    Using something like Mach3 really makes you feel ripped off, but however... controls come with higher quality machines, so since I have perfectly fine Fanuc and Haas controllers with my machines, I use them.
Page 7 of 7 567
  1. Low rapid traverse speed
    By megaisomot in forum Uncategorised MetalWorking Machines
    Last Post: 07-01-2008, 02:36 AM
  2. rapid speed
    By drafterman in forum DIY CNC Router Table Machines
    Last Post: 11-03-2007, 05:31 PM
  3. Haas rapid move ?
    By binzer in forum Haas Mills
    Last Post: 06-29-2007, 01:11 AM
  4. rapid speed
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 06-04-2007, 03:23 PM
  5. Possible to change tools while XY rapid??
    By little bubba in forum Fadal
    Last Post: 12-01-2005, 03:08 PM
