588,658 active members*
4,784 visitors online*
Page 7 of 7 567
Results 121 to 122 of 122
  1. #121
    Nov 2010
    59
    correction, the first transformer is fed from two phases @ 240v = 415V each into 0v and 415V giving me no where to go to reduce the voltage on the taps, pretty strange getting a potential of 240v from the 0v tab to earth ! At least I have learnt something today, just because the transformer has a 0v tab, dont mean its connected to 0v
    I guess I am going to have to take turns off the transformer, is there a post and or pictures of the proceedure ?
  2. #122
    24222
    You mention this transformer is fed across two phases, this represents a 415 single phase transformer, the star or neutral is not used.
    If you want to reduce the secondary, it is usually wound on last, if so you are in luck as you take turns off as needed, and you can calculate as a minimum that there will be around 1.5 to 2 turns/volt.
    With a square lamination type it is a bit uglier than doing it on a toroid, but it is possible with care.
    Al.
    Albert E.
Page 7 of 7 567
  1. Retrofit advice on Hurco km3P
    By Jackal66 in forum HURCO
    Last Post: 10-27-2010, 02:58 AM
  2. Hurco KM3P won't zero home in x axis
    Last Post: 05-29-2010, 03:09 PM
  3. Hurco KM3P
    By ivanfed in forum HURCO
    Last Post: 04-20-2009, 10:48 AM
  4. Hurco KM3P HELP
    By winds1sj in forum HURCO
    Last Post: 12-20-2008, 08:44 PM
