![Quote](images/misc/quote_icon.png)
Originally Posted by
RotarySMP
I do have decent measuring tools, (once my father brings out some decent Mitutoyo telescoping guages at christmas, so I should be better able to precisely measure bores cause my current ones are a definate weak point in my tooling).
I am guessing that the preload range for these precision AC bearing is going to be less than a thou (0.025mm) from too loose to too tight, as Pat points out. What do you guys use for such accurate shims? McMC seems to only have shims starting as 0.001" (and only for some sizes, for 20mm ID I think the thinnest are 0.003". Beer can is about 0.004" (and I don't like using aluminium in machine parts).
Herbert, did you end up using the thin Aluminium foil from your sandwiches to fine tune the preload? What thicknesses did you end up using on your AC bearing pairs on your last couple of spindles?
Looks like I'll order a bunch of shim packs form McMaster Carr and get a friend to bring them over when they do an aircraft delivery.
Some thoughts:
You might want to consider a line boring setup for machining bearing pockets on your lathe if the pockets are at all large relative to the lathe's capacity. Such an arrangement will be more rigid.
RE measuring these bores, I think telescoping gages are going to be tough. It's really hard to achieve the degree of accuracy necessary with them, and they're very subject to technique. A dial bore gage would be preferred but expensive. I haunted eBay for a long time before I got a reasonable deal on my Mitutoyo bore gages.
But there is an easy and accurate solution. Make yourself up some go/no go plug gages. You can measure their OD's with a micrometer. I've used this approach a number of times before I got the bore gages and it works very well.
On the shim stock, you're just going to have to run some experiments to see what is needed. It won't be a lot, but I don't know that it's way less than 0.001 either. If it was me, I'd use shim stock and Herbert's method of machining that into shims.
RE the whole DIY question, machinist's are DIY by definition. A machinist should be able to build whatever they desire with the tools at hand. There are no end of examples of talented machinist's accomplishing wonders ranging from POWs in Japanese camps building machine lathes from nothing (great story from Lautard's books) to the many examples on these boards. It is poor marketing that leaves the DIY moniker in short shrift.
People who build airplanes in garages don't call them DIY or homemade, they call them experimental aircraft. Better marketing!
I would suggest the equivalent here is that your spindle is "shopmade" as you've demonstrated you are a machinist.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
