588,464 active members*
6,481 visitors online*
Page 7 of 8 5678
Results 121 to 140 of 150
  1. #121
    Oct 2009
    874
    Re: A Desktop CNC by David A
    Install the right one from the bottom, pushing it up against the foot blocks.
    Attachment 506268
  2. #122
    Oct 2009
    874
    Install the left one loosely, about 10" away.
  3. #123
    Oct 2009
    874
    The catch basin from the front.
  4. #124
    Oct 2009
    874
    And the back.
  5. #125
    Oct 2009
    874
    The filter screen.
    - - - Updated - - -
    And the pump.
  6. #126
    Oct 2009
    874
    Adjust the left guard rail and slide the catch basin in.
  7. #127
    Oct 2009
    874
    Catch basin installed.
  8. #128
    Oct 2009
    874
    Leave some slack for the coolant return tube to pull out catch basin 5"-6" for cleaning.
    Attachment 506330
  9. #129
    Oct 2009
    874
    The vacuum system.
    Remove the screws and plug on the left side.
    Attachment 506368
  10. #130
    Oct 2009
    874
    The manifold with a few standard plumbing items.
    - - - Updated - - -
    Coupler and nut installed.
  11. #131
    Oct 2009
    874
    Standard elbow pushed into the coupler.
    - - - Updated - - -
    Gasket installed.
  12. #132
    Oct 2009
    874
    Position the manifold assembly under the machine and tighten from above.
    Vacuum system installed.
  13. #133
    Oct 2009
    874
    Grid with 216 suction points.
  14. #134
    Oct 2009
    874
    Vacuum manifold from underneath.
  15. #135
    Oct 2009
    874
    Adjust elbow to fit your layout.
  16. #136
    Oct 2009
    874
    Dust Collection.
    The dust shoe connects to hose from the back.
    Front view.
  17. #137
    Oct 2009
    874
    And the back.
  18. #138
    Oct 2009
    874
    Can be installed on many designs.
    Tool changes without removing anything but the magnetic brush ring.
    For 80mm to 100mm spindles.
    Threaded 4" hose connector.
    Brushes for 1/2", 3/4", and 1" cutting depth bits.
    Attachment 506718
  19. #139
    Oct 2009
    874
    Profile of dust shoe.
  20. #140
    Oct 2009
    874
    And with dimensions.
    Spacing between CL spindle and hose connection can be custom made.
Name:	006 Dimensions.jpg
Page 7 of 8 5678
  1. David A's Benchtop CNC Version 2
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 09-09-2021, 02:08 PM
  2. Replies: 0
    Last Post: 06-06-2018, 01:50 PM
  3. KL-6090 Desktop Cnc Router desktop,(24 x 36 x 6 inch)
    By automationtechinc in forum For Sale Only
    Last Post: 09-18-2015, 09:05 PM
  4. KL-6090 Desktop Cnc Router desktop,(24 x 36 x 6 inch)
    By automationtechinc in forum News Announcements
    Last Post: 04-28-2015, 11:23 AM
  5. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
