588,687 active members*
6,599 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Model V8 engine plans required
Page 7 of 27 5678917
Results 121 to 140 of 525
  1. #121
    Dec 2006
    603
    Today I decided to finish the air cleaner lower pan. I found a piece of scrap large enough and faced it and turned the OD.
    The air hole and mounting hole were both drilled from the bottom side.
    The ID of the mount was bored with the boring bar
    Then by some miracle, the part was parted off.
    Then the front was cut to shape and that is where the camera battery died.
    It was finished off in the CNC mill. I think it is a close replica of a 14 inch Edelbrock. Only without the Edelbrock.
  2. #122
    Dec 2006
    603
  3. #123
    Feb 2010
    3447
    Talking
    This is the coolest thing ever and very inspirational.
    Quote Originally Posted by stevehuckss396 View Post
  4. #124
    Nov 2010
    360
    Very cool!
    What did you darken the recesses with?
  5. #125
    Dec 2006
    603
    Quote Originally Posted by dbrija View Post
    I used testors model paint. I thinned it some but not alot.
  6. #126
    Oct 2010
    110
    its suddenly occurring to me i need a faster internet connection and a comfier seat....
    theres too much here! and everything leads to the next!
    now im off to see if anyones tried making an induction heater from a welder or summink for case hardening... my workshop and flames dont mix
  7. #127
    Dec 2006
    603
  8. #128
    Feb 2010
    3447
    this just blows me away.
  9. #129
    Dec 2006
    603
    Made a few carb parts today
    Air bleed adjust screw
    Fuel adjusment screw
    Fuel fitting
    Finished the machine work on the rear float bowls by adding the fuel passages.
  10. #130
    Feb 2010
    3447
    what size screws are those! Sooo small. How are you even tapping those? Being that these parts are so small, do you have to use special mini end mills and cutters on your mill/late?
  11. #131
    Dec 2006
    603
    Quote Originally Posted by diyengineer View Post
    They are #2-56 X .500 long. The screw was drilled with a .029 drill bit and then the .030 needle was pushed in with a little loc-tite on it.
    Nothing special used. Just need to take your time and make light cuts.
  12. #132
    Dec 2006
    603
    Scratch carburetor off the list. Thanks to Mr. Bob Farr I was able to get a piece of brass to make the barrels. Everything is made except the throttle lever and the gaskets. I think I'm just going to wait until everything is done and make gaskets for everything all at one time.
    The screw to the right adjusts the fuel and is adjusted at full throttle. The screw in the center will adjust the air bleed to lean out at idle.
  13. #133
    Dec 2010
    Throttle Diameter?
    Hi there,
    First off.. Awesome work!
    If and when you make some plans for this little beast, I'll definitely be purchasing them!
    Just wondering if that throttle diameter will be big enough? Or do you plan to open it out during your tuning process?
    Nick
  14. #134
    Dec 2006
    603
    Quote Originally Posted by 3rnieball View Post
    Hi there,
    Hi Nick.
    I have 49 pages of prints done right now and another 20 - 30 to go. I am to the point where I have caught up with the drawings. I now build from my own drawings. Easier to catch errors and omissions.
    Throttle will be big enough. Most people tend to over carb, even full size hotrodders. I started out small but I doubt there will be any changes. The engine needs atomization and that size should provide a small enough area.
    Cheers!
  15. #135
    Feb 2010
    3447
    "technically" couldn't you enlarge these plans and make a much larger engine? Say like a 1 liter v8?
  16. #136
    Dec 2006
    603
    I imagine you could but there are plans for larger engines that would be a better choice. At this size there are things that are not included like pressure oil system. Personally I wouldn't.
  17. #137
    Feb 2010
    3447
    ooo ok. I seee!! They have plans for radial piston engines for planes??
  18. #138
    Apr 2010
    486
    I've not seen plans for a radial engine for airplanes.
    But...
    Elmer Verburg published a set of plans for a radial steam engine. That might be a starting point for something you could design yourself.
    Tom Wade Machinist -- Project Plans
    Tom
  19. #139
    Nov 2010
    Are you asking if anyone sells plans for radial engines such as these.
    Ageless Engines
    I would like to build the 9 cylinder one of these days.
  20. #140
    Dec 2006
    603
    Well I'm getting real close. All i need to do is part off the ends, cut a flat on the front shaft and thread the rear shaft. I'm not going to do anything fancy like counter weights. I don't want to screw it up.
  1. Engine Plans
    By nzer in forum MetalWork Discussion
    Last Post: 08-03-2012, 05:14 PM
  2. I.C. engine plans
    By cumminsman in forum I.C. Engines
    Last Post: 04-10-2012, 11:43 PM
  3. Does anyone have any good jet engine plans?
    By flyguy1254 in forum Hobby Discussion
    Last Post: 04-16-2010, 10:28 AM
  4. Jet Engine plans
    By godspeed in forum Hobby Discussion
    Last Post: 05-18-2007, 11:34 AM
