588,197 active members*
4,789 visitors online*
Page 70 of 76 20606869707172
Results 1,381 to 1,400 of 1506
  1. #1381
    Sep 2011
    1183
    Re: Mach3 2010 Screen set
    Quote Originally Posted by RCaffin View Post
    That suggests that the M6Start and M6End macros might be missing from the macros/Mill folder.
    Cheers
    Roger
    I will check that out thanks..
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  2. #1382
    Sep 2011
    1183
    Rodger, they are in the folder I noticed two different Mach 3 folders on my "C" drive they both have M6 End and M6Start marcos One is labeled Mach3 and the other labeled "Mach3 new" It has been so long since I installed the 2010 screen set.
    Thanks Lou
  3. #1383
    In general config, do you have tool changes set to "Stop Spindle, wait for Cycle Start"?
  4. #1384
    Sep 2011
    1183
    Gerry, I am not sure I will have to go check and see.
    Thanks, Lou
  5. #1385
    Sep 2011
    1183
    Gerry, It was not checked that must be it.
    Thank You Gerry
  6. #1386
    Sep 2011
    1183
    Well, I tried my machine with the change made now after setup it goes through the routine lose and fixed touch plates I get the start spindle pop up. Now after clicking the message box to start it goes back to home or very close to zero zero any ideas on what I need to do?
    Lou
  7. #1387
    Post your g-code.
  8. #1388
    Sep 2011
    1183
    Gerry, I tried to upload the G code and I get this " Your file of 1.28 MB bytes exceeds the forum's limit of 500.0 KB for this filetype." not sure what to do.
    Lou
  9. #1389
    Sep 2011
    1183
    Post your g-code.
    Gerry, can I email the file to you @ the email from your website?
    Lou
  10. #1390
    Sep 2011
    1183
    Part of the G code file.
    Lou
  11. #1391
    Quote Originally Posted by LouF View Post
    Lou
    Yes.
    I won't be able to look at it until tomorrow evening.
  12. #1392
    Sep 2011
    1183
    Gerry, thanks.
  13. #1393
    If you mean after the first tool change, then it's Aspire sending it to the home position. You can change the home position in Aspire, edit the post, or use one of the posts on my website.
  14. #1394
    Sep 2011
    1183
    It sends me home after I do the setup touch both plates the box pops up to start spindle. So I manually start the spindle through SupPid click the box and it sends me home instead of cutting the work pieace. This is before I even do a tool change.
    Lou
  15. #1395
    It returns to the previous location after going to the fixed plate.
    Is that what you are seeing?
  16. #1396
    Sep 2011
    1183
    Okay, I set up my job center of the table I then click the auto-zero tool change Icon, my spindle moves down to the touch plate on the material. My spindle then moves to the second fixed plate touches the plate and then it move back over the material on the table. The box pops up to start spindle I start my spindle I click the box and then my spindle moves to the home postion and stops not down to start cutting the material.
    Lou
  17. #1397
    Do you have g-code loaded?
    What is your tool change position set at in the screenset?
    The macro ends after it starts the spindle, so I'm thinking it's the g-code?
    What happens with no g-code loaded?
  18. #1398
    Sep 2011
    1183
    I do it with g code loaded I will try it without it loaded.
  19. #1399
    Sep 2011
    1183
    The tool change position is set at.
    Fixed plate X: + 16.963
    Fixed plate Y: + 0.341
    After zeroing without g code loaded it goes through the routine like normal it stops above material like it should after touching the two plates but No popup box to start spindle just a message in the window below the buttons on the Run screen saying "Material Offset now Caculated in Inches"
    Lou
  20. #1400
    The spindle stat option only happens when g-code is loaded.
    I think what's happening is your g-code starts running after you click the box to start the spindle, and the machine is moving where the g-code sends it.
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
