lock down system...
As Ger21 and or Greybeard and many others have talked about. Until I get my t-slot solution done I am going to go with the t-nut solution. I have used my CNC to drill a hole every 3" on the Y by every 4" on the X this gave me about 90 holes I think. Each hole is a tight fit to a 1/4 20 t-nut. A t-nut you ask? A t-nut looks like a top hat but the brim has been cut and folded upward (up the stove-pipe of the top hat). These 3 or 4 spikes sink into the wood as the brim comes up to meet the wood. The "stove-pipe" part slips up into the hole that was drilled by the CNC, 19/32's dia. I thnk.
Now with holes every so many inches I will use a flat 2" square of alluminum with a hole bigger in dia than the 1/4 20 bolt but only enough to allow the threads to slip by. I will use a hand drill or an air wrench or manually with a socket wrench to pull the t-nut up to the bottom of the bed of the machine allowing the t-nut shaft to go upward into the drilled hole allowing the spikes to secure it.
I can now use a 1" by 4-6" strap of alluminum with a hole in it tha the 1/4 20 bolt slides thru down into the t-nut to secure my wood by holding it down. I am also cutting with the cnc some small 1" and .5" thick dense plywood into little paddel or banjo shapes. These will have a hole for the bolt to they can secure projects from the sides to preven slippage latterally.
I will upload another video as soon as the setup is all finished.
Thanks for the DIY ideas guys!
Coog
Building Stage:[xxxxxxxxxxxxxxxxxxxx] 105%
Finishing Stage:[xxxxxxxxxxxxxxxxxxx-] 95%
