Originally Posted by
Fish4Fun
In a conventional Brushed DC motor the commutator alternately energizes some number of coils, and the amount of current that is drawn is dictated by the supply Voltage, the winding Inductance, the winding Resistance and the period of Time any particular coil is energized.
A conventional 3-phase VFD provides a 3-phase signal to a 3-phase motor. The motor rpm is directly linked to the frequency of the drive signal. The amount of current required is dictated by "rotor slip". Rotor Slip is a measurement of the phase angle difference between where the rotor "should be" vs where it actually is. Under no-load conditions there should be very negligible slip, as the load increases, more current is required to keep the rotor "where it is suppose to be", and the "slip angle" increases.
Fish
I know I came to the game late but I read through all the posts and maybe can make some things clearer.
The brushed DC motor current relies on BEMF to limit the current, with no load, the BEMF voltage approaches the applied voltage and current is minimum, as the load increases, the rpm drops and hence the difference between BEMF and applied Voltage increases and in turn current.
A normal 3ph induction motor can never be synchronous, as it requires slip to induce a magnetic field into the rotor.
the lower the slip, the lower the current, apply a load, the rpm drops and the slip increases in turn as does the current.
The difference in construction between a AC P.M. motor and a BLDC is indistinguishable.
The difference is in the commutation, the BLDC is so named because it represents a DC brushed motor turned inside out, and only two of the 3 windings are energised at any given time.
The P.M. AC has three phases applied to the stator 120deg apart, and can be truly synchronous.
The amount of poles of a BLDC or P.M.AC indicates how many electrical revolutions or cycles there are per mechanical revolutions.
e.g. a 8 pole motor has 4 electrical revolutions per mechanical.
Al.
Albert E.
