Hi matt, Thank you. actually we do have some progress on the SVM-2 ATC recently becuase we have been waiting parts for SVM-0...SIGH...
Here are some pictures during the SVM-2 ATC prototype building process.
If I'm correct, I should upload the progress from the SVM-2 body painted..
And then moved on to the super heavy base with a simple swarf removing structure.. It's an easy design. (must declare that this one is a special stand for customer. The formal stand with commercial SVM-2 will be a developed one with coolant system and swarf drawer inside)
And then installed our BT30 spindle unit and adjusted the perpendicularity to worktable.
And then the aire cylinder system.
Welding the ATC bracket.. the steel boards were cut with CNC laser so it will be accurate.
ok.. try to install and locating the ATC
powder cotated ATC bracket. and rail covers, gas spring installed.
some details of the ATC and spindle unit.
almost forget the big AC SERVO spindle motor system.. the AC mtor is so big so I will need to design a bracket to put it on to the head..
This is the SVM-2 ATC progress so far.. will update next progress later. Next progress will be mostly the electric system and controlling system connection and tests. And enclosures...It's another big part to do:tired:
