Originally Posted by
Mmpie
Yes that's right, soft limits will prevent over travel on the OMIO in its default set up.
There are two coordinate systems, machine coordinates (g53) and work coordinates (g54, 55, 56 etc). Your machine coordinates are the machines actual location relative to the home position, when you click ref all home on start up the machine will hit the switches and know that it is at home, the machine will be in its X0 Y0 Z0 position.
Work coordinates are where you set up your work piece, so you move X, Y and Z to the reference point for your work piece and click zero x/y/z that is setting the zero point for the job, so the machine knows where the work is within it's working envelope in reference to the machine home point.
The default coordinates you will see on your screen are the g54 work coordinate system, unless you either click 'machine coords' button they will display the machines actual position, or you change to one of the different work coordinate systems (g55, g56 and so on).
