Without lube, you are going to break cutters on aluminium. Slower feed rates only make it worse because they promote rubbing instead of cutting which dulls and heats the endmill - you're (unintuitively) better off
increasing your feed rate up until deflection becomes your enemy.
I went for the table/enclosure for a number of reasons:
- space in the shed is tight, so I wanted something /just/ big enough without being too big, but sturdy enough to not rattle around.
- I needed somewhere to keep the control box out of the way, and somewhere to put the laptop.
- I knew it would be mostly metal working so there'd be coolant flying around, so it needed to be on a waterproof tray.
- I wanted to control the amount of rubbish flying around. But still see what was going on.
- I wanted to save my face from bits of broken endmill flying at speed when I stuffed up (again).
That said, it ain't perfect. The enclosure adds another two steps (remove/replace front acrylic wall) to every damned tool change. It gets in the way of overhanging stock. It makes life less convenient when doing the cleanup (even though all the walls are just drop in/out, it needs doing and they need somewhere to live when not on the machine) after the job. Oh, and it was considerably more expensive in bucks and time than a dust shoe.
If I was going to do all or mostly wood, well, the top of the enclosure lets dust fly fine, so it woodn't (hurr hurr) be that great - a dust shoe'd be much better. But for metal it's a pretty handy dandy setup and I have no regrets
![Smile](images/smilies/smile.png)
