Originally Posted by
jhowelb
Danny,
After installing freemill on a laptop I have I'm having a bit better luck. At least I can post the part, now if I can only get it to give me enough detail in the hands......
Thanks again!
Hi there,
great news... and glad you stuck with it.... I think your problem with getting it to post before will be down to the default txt editor on the previous system.
re: detail in the model.
settings I used when I ran the model were tool diameter of 3mm and corner radius of 1.5mm, This describes a 3 mm ball nose as far as FREEmill is concerned... 15% stepover = 0.45 mm
If you "generate" at those settings... then "simulate" you should see the same kind of result as in the image I put up.. then just "Post" using the "general" post processor.
Well done.. and hope it works out for you.. if it does it gets you into 2.5D / 3D carving for zero cost...
All the best
Danny
What one man can do another man can do..
BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
