I notice a lot of questions on how to fit the sensor into the 1617 EVS, so I figured I'd share how I did it while I got my router apart to fit it for a new power cord.
I took some pictures but I forgot to document the removal of the switch and where to move the wires but that is pretty straightforward. Just rearranging of the quick disconnects direct to the brush terminals.
To fit the sensor I took the top off and used adhesive sign vinyl to cover half of the shaft just below the armature. Then I drilled the top at an angle to intersect the taped off section and then tapped it to 3/8"-16. I used a piece of delrin rod and drilled it for the sensor, then threaded it to 3/8"-16.
I pulled the wire through until the sensor was just exposed, then several layers of varying sizes of shrink tubing to secure. Then it is just threaded into the hole estimating the right spot to drill the outer cover for the wire to exit.
The photos should be clear enough to show what's involved. The upper hole in the router cover is to attach a ground wire to the spindle via banana plug for the zero function.
This integrated mod might not be for the faint of heart. If you drill in the wrong spot or the wrong angle it won't work. Just thought I'd share how I did it. And yes, it works.![]()
