Hello!
When you say that the 2nd skim is in great effort to make the corners, Does the rough pass/C1 only burn a square without corners? And are we talking about a die or a punch?
Some other questions i got:
- What's the name of the control? LQ(1/2)W or is it an LN series?
- Are you using the built-in HeartNC/Qvic software to create a program or are you using a cam-software; If so, which one?
- Does the part contain any 4-axis/taper machined surfaces or is it a straight cut?
- What are the problems you are having with the corners? Are they not round? Is the finish not good? Wrong radius? (larger or smaller than what it is supposed to be).
If you can supply me with the NC-code i could check it out to see if there's anything wrong, But i need to know some stuff about the part first:
- Material:
- Height:
- Taper/4-axis or straight cut:
- Top and lower guide position: (Close to the part of a bit over/under)
Take care!
