587,830 active members*
2,955 visitors online*
    Nov 2009
    30
    1001 lub timeover
    Hello
    I have a yang smv-1000 cnc machine with a fanuc 0M-D controller which stopped working yesterday when i tried to home the z axis
    the z axis went to it's home position and the home position led turned on but after that an error message( 1001 LUB time over ) appeared
    can any one please tell me what caused it ?
    and how to fix it or skip it ?
    i have lubricated the machine but nothing happened.
    And if the machine does not drive to the reference point does alarm appears?
    Try to power on the machine and not doing anything 5,10,15,20 minutes.
    This alarm usually appears if the pressure switch does not receive adequate lubrication pressure in a time frame that is set up machine manufacturer.
    Check does the on central lubrication pump raises the pressure on gauge, if exists pressure this mean that the oil pressure switch faulty or oil not generally comes up to him.
    Oct 2008
    106
    Alarm 1001
    Press RESET + FEED HOLD to reset alarm and make sure to lube all axis after reset alarm
    Ahn Vuong
    [email protected]
    Nov 2009
    30
    thank you very much it worked will
    i think fanuc is a little complex comparing to other pc based cnc's
  1. Replies: 5
    Last Post: 03-18-2015, 09:37 AM
  2. Seal/Washer In UNIVER Valve Type AE 1001 Replacement On Bridgeport Help!!
    By Huntersyv in forum Bridgeport / Hardinge Mills
    Last Post: 02-07-2006, 08:02 PM
