588,653 active members*
6,568 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > What speed and pitch ball screw
Results 1 to 1 of 1
    Feb 2005
    149
    My bench mill uses a 1 inch diameter 10 turn per inch (imperial) screws at the moment. I thing it's equ to the RF2 (See picture)
    I will replace the screws with a suitable size zero backlash ball screw and nut.
    I am considering using direct drive from the motor to the new screw. I aim to buy a ball screw with 5mm per turn.... that works out at about 5 turns to the inch. What maximum speed should I set the motors at ? I'm using Mach3 at the moment.
    Do you consider this adequate. I plan to be milling either aluminium or small steel parts for model engines, so nothing too big and heavy.
    Many thanks....
    George
