587,546 active members*
3,727 visitors online*
Thread: Door Open
Hybrid View
    Nov 2009
    Question Door Open
    Good day, as I have posted yes I am a green horn to this site. I'll post some shots of my cave a little later but right now I'm just trying to get organized and set up. I'll start with an easy question. On My Tl2 the error message keeps coming up that the "door is open" I assume that the little sensor at the back of the saftey cover is in defect some how. So my question is can I just hot wire it till the new pickup arrives or how do you test to see if that is in fact the problem. Roly
    Jun 2005
    138
    If the switch is electrically "closed" when the door is shut, just jumper across the switch and see if the error message goes away. If the switch is "open" when the door is open, just unplug it to test the error condition.
    Feb 2010
    1184
    Look to see if it toggles in the diagnostics page. Did you turn on Setting 51 to see if it works that way?
  1. Door open request
    By zippyd in forum Daewoo/Doosan
    Last Post: 05-09-2016, 11:25 AM
  2. 2216 FX Run spindle with door open???
    By Chuck Pressure in forum Fadal
    Last Post: 10-26-2009, 03:26 PM
  3. TL-1 door open alarm won't go off!
    By donsbad89 in forum Haas Mills
    Last Post: 09-25-2009, 04:01 AM
  4. OKK G4 tool change door open
    By dannystooblue in forum OKK
    Last Post: 09-18-2009, 02:26 PM
  5. kira vtc30a door won't open
    By nevron in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2008, 03:30 PM
