587,997 active members*
3,481 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > OKK G4 tool change door open
    Sep 2005
    164
    I just wired up an OKK G4 Graphite mill with the tool changer in the back with a tilt out door. When I turned on the air to the machine it opened the tool change door. I do not have manuals to tell me how to close the door manually. Any help would be appreciated.
    Danny
    Sep 2005
    164
    Got it figured out... or atleast worked it out
    I am sure there is a manual way to open and close the tool changer door because there is no external way to access it but I haven't figured it out yet. What I did to get it to close was to turn off the machine, turn it back on and cycle a tool change.
    Danny
    Jun 2006
    25
    ATC door
    OKK electrical manual has the list of M-codes for the machine in it. Do not be fooled when you first open the book and think everything is in Japanese. They alternate chapters in the book. First Japanese then English. We do not have a G4 electrical manual here but in the DGM400 manual M100 opens the ATC door and M102 closes the door. Most of OKK machines will follow the same set of M-codes.
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. orient tool for tool change Hall effect?
    By Luslugger in forum CNC Machining Centers
    Last Post: 04-25-2009, 12:24 AM
  3. kira vtc30a door won't open
    By nevron in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2008, 03:30 PM
  4. Very slow tool change on Tool Room Mill
    By Capt Crunch in forum Haas Mills
    Last Post: 12-21-2007, 07:20 PM
  5. Mini Mill door open alarm
    By paptep in forum Haas Mills
    Last Post: 11-21-2005, 10:31 PM
