Hello,
I work at dmc100v with Dialog 112. I’d like to read something about cycles and programming at home.
Does anyone have a guide for the Dialog112 in PDF?
Thanks in advance
Hello,
Thanks in advance
Hello, only one question: difference between Dialog 12 and Dialog 112?
D 11 and D12 certainly have similarity, for example programmers' manual
Regards Gerhard
Dialog 11 and 12 are very similar, that’s right.
But Dialog 112 is quite another matter. Mitsubishi had made this controller before Deckel and Maho joined forces.
The 11th and 12th are from Grundig.
Grundig stays on the 112 as well and the buttons are similar to the dialog 11,12. But you see that Mitsubishi stays everywhere in the switchgear cabinet and on the advance engines.
Dia 11 and dia 112 are very similar in construction of the whole servicing and in general… I think the dia112 was made for low volume production, and the dia 11 for small parts that one can make oneself…
Whereby one can do it at the dia 112 as well if one knows the crunch point. Many commands are oriented to the firm and are individually allocatable with functions.
D11 and D112 are really similar. The D112 brings along its own cycles and is very functional. (G171 – rectangle pocket, G175 – thread etc.). The contour calculator is almost even constructed.
Unfortunately I don’t have PDF, but I could get an aged manual.
Regards
