588,503 active members*
4,804 visitors online*
    Sep 2011
    main power supply malfunction
    we have a mazak sqt-300 mazatrol pc fuzion. we encountered an alarm (main power supply malfunction. how to fix the problem?
    Jan 2011
    350
    If you're lucky you've got some electrical equipment such as your main contactor not contacting properly, some fuse burned or breaker activated, just check you get the proper voltage going to your power supply. If you get the proper voltage going to the power supply, then it'll be the power supply that needs to be replaced.
    Cheers.
    Jun 2022
    Re: main power supply malfunction
    We have a mazak Slant Turn 60N and we have been experiencing the same alarm on our machine, alarm "main supply power malfunction". We would have to cycle the power every morning and the alarm would clear. Any advise on this would be much appreciated.
    Jun 2022
    We have a mazak Slant Turn 60N and we have been experiencing the same alarm on our machine, alarm "main supply power malfunction". We would have to cycle the power every morning and the alarm would clear. Please see attachment for the alarm. Any advise on this would be much appreciated.
  1. How to connect laser tube/power suply to the main board?
    By zoran0502 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-02-2014, 10:49 PM
  2. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  3. Wiring main power to Drives
    By allymax in forum Servo Motors / Drives
    Last Post: 02-15-2010, 05:16 PM
  4. A2100 Power Supply Malfunction
    By icesoft in forum Cincinnati CNC
    Last Post: 10-01-2009, 01:31 AM
  5. MAIN BOARD POWER UNIT
    By gabedrummin in forum Fanuc
    Last Post: 09-27-2009, 09:37 AM
