Hello all. I am setting up a Novakon NM-135 (KX3) CNC mill and I could really use some help setting up Mach3 for the system.
What parameters need to be programed into Mach3 to get the system up and running?
Thanks for the help.
-Blane Nelson
www.tacticalpyrotechnics.com
Have you downloaded the XML setup files from Novakon? They are probably a good start. Once you have things running you can tweak them based on your experience and feedback from other NM 135 users.
http://www.novakon.net/10.html
