587,326 active members*
3,125 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Driving a 4 pole ac servo with a 6 pole drive
    Feb 2004
    35
    I was wondering if it is at all possible to drive a 4 pole ac servo with a drive designed for a 6 pole motor. I have everything all hooked up and the motor just jitters. The motor is a baldor bsm80b ac servo, and the drive is an emerson fx-316 drive. The drive can't be set up for 4 poles as far as I know. Is there any trick to fool the drive?? I don't need any positional accuracy. Just want it to spin.
    24223
    Usually the drive is set for 60 degree phasing or 120 deg phasing and the commutation is taken care of by the hall effect or resolver sensor. Do you have the phasing right (motor phases) ?
    Al
    Albert E.
    Feb 2004
    35
    I think I have the phasing right. Is there any way to check this? The servo leads are U,V,W, and R,S,T on the drive. Don't think they will match in order since they are different manuf.
    24223
    What type of feedback do the Baldor use? Hall effect switches? they need to be phased correctly with the motor windings.
    Al.
    Albert E.
    Feb 2004
    35
    They use resolver feedback, and I aligned it as they recomend(emerson) for their drive. Wired the phases up all 6 different ways and still nothing.
  1. Using surplus servo motors as spindle drive
    By Swede in forum Servo Motors / Drives
    Last Post: 03-16-2008, 02:05 PM
  2. Where can I find Detail Specs Servo & Drive MEans ?
    By Calico in forum Servo Motors / Drives
    Last Post: 02-28-2005, 06:37 PM
  3. Brushed servo drive replacement
    By motordude in forum CNC Machine Related Electronics
    Last Post: 07-06-2004, 07:09 PM
  4. Cheap 0 Clifton and servo drive selection (advice needed)
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 04-14-2004, 04:21 PM
  5. R90H Servo Drive
    By Verboten in forum Servo Drives
    Last Post: 03-31-2004, 04:10 AM
