586,599 active members*
3,708 visitors online*
Results 1 to 8 of 8
    Jul 2007
    13
    welding on machine
    ive got a fast question, i need to repair a part that is not removible from the machine, it requires alittle mig welding, im wondering before i do anything is this going to harm my machine?
    dont know if it makes a difference but im useing stepper motors
    Oct 2009
    28
    I only know about welding on cars.
    It can go wrong, mostly it doesn't
    I describe her the reason why it can go wrong:
    Welding invokes HF AC currents.
    As many know, a battery acts as a wire for HF.
    So the currents go throug the wires, and can invoke a dangerous tension over other components like alternators, ecu,...
    So it's always safer to disconnect the battery.
    In your case, I don't know your setup:
    When you disconnect all wires from your machine, leaving the steppers or servos on it, but disconnected, you're safe.
    When you weld without disconnecting and keep the mass clamp close to your welding area, you're nearly safe.
    Follow also the path of current.
    Welding on the X-axis, while having the clamp connected to the machine base, makes the current go througt slides, bearings, spindles... not good.
    Jul 2007
    13
    Quote Originally Posted by RalcoBe View Post
    i had planned out disconnecting all the wiring to and from the machine, i just dont want any problems i would hate to end up replacing stuff from the welding.
    Oct 2009
    28
    In that case, you're safe. Leaving and unconnected motor can't kill him.
    Leave your high freq off if your unit is so equipped and it wouldn't hurt to tie all the leads for each motor together and ground them.
    I used to be appalled, now I'm just amused.
    Oct 2009
    28
    Quote Originally Posted by KIMFAB View Post
    HF current is invokend, even when not welding with an HF source.
    Jul 2007
    13
    alright thats what i wanted to hear :cheers:
    I was talking about extra high power HF, used by older machines. Comes in real handy when welding light or rusty metal. Plays he!! with my fluorescent lights when I weld with it on.
    Modern machines use different methods, such as fancy square waves.
  1. CNC Welding Machine?
    By Kraig1 in forum Waterjet General Topics
    Last Post: 05-16-2012, 02:22 AM
  2. CNC TIG WELDING MACHINE (Router Type)
    By Khalid in forum Uncategorised MetalWorking Machines
    Last Post: 07-11-2009, 05:11 PM
  3. Tig welding around your machine
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 09-24-2007, 02:40 PM
  4. Please Recommend a Home welding machine
    By ThomasAlva in forum Welding Brazing Soldering Sealing
    Last Post: 08-23-2007, 07:34 AM
