586,117 active members*
3,319 visitors online*
Results 1 to 3 of 3
    Jan 2014
    6
    PathPilot fix?
    I have a Tormach PCNC1100 and I want to hook my 4th Axis up to my Machine because it has good clearance for my Tool changer. I ordered the proper Motor and stepper driver from Tormach, the problem is they will not tell me how to go into Pathpilot and change the Axis[3] Scale.. They have a 90:1 gear ratio and I am going direct drive because I am only doing light engraving on a cylinder. Does Anyone know how to Hack into PathPilot? I need to get this to work and hope it can be done... Thanks in advance, Bradly
    Aug 2016
    132
    Re: PathPilot fix?
    You set your steps per degree on the SCALE line of the A axis (AXIS 3) in your INI file. This video will get you to the INI file:
    https://www.youtube.com/watch?v=SFxzUPSGwOY
    Do you know the microstepping ratio of your driver? Your scale will be the steps/rev of your motor multiplied by the microstepping resolution over 360 divided by your gear ratio.
    For example:
    200 steps/rev from the motor
    16 microsteps per step
    Gear ratio of 90:1
    (200*16)/(360/90)
    3200/4
    800 steps per degree
    Jan 2014
    6
    Re: PathPilot fix?
    Quote Originally Posted by footpetaljones View Post
    For example:
    Gear ratio of 90:1
    (200*16)/(360/90)
    3200/4
    It looks like the stepper driver is set at 1600 Pulse/Rev. I do not have the Motor yet so not sure on the numbers. I was going to use a timing belt system to reduce gear ratio but I have not purchased that yet.. Very interesting video, Its not going to be as hard as I thought.. Thank You!!!!
  1. PathPilot 2.x and PathPilot Simulator
    By draper-ballou in forum Tormach PathPilot™
    Last Post: 01-01-2019, 01:42 AM
  2. PathPilot® v2.1.3 Now Available
    By kstrauss in forum Tormach PathPilot™
    Last Post: 07-16-2018, 11:40 PM
  3. PathPilot kit
    By burbingus in forum Novakon
    Last Post: 06-30-2018, 02:01 AM
  4. Pathpilot 2.02
    By popspipes in forum Tormach PathPilot™
    Last Post: 04-18-2018, 03:46 PM
  5. Replies: 2
    Last Post: 12-03-2017, 12:02 AM
