588,243 active members*
4,142 visitors online*
    Aug 2009
    13
    G0704 Z ball nut oiling
    I need peoples thought on how to setup an oiling system for the ball nut on the G0704 Z axis. I have the y and x axis figured out. Any thoughts, pictures or anything would help.
    Dec 2013
    5722
    Re: G0704 Z ball nut oiling
    Given that the screw is vertical, the easy way is to put a copper tube just touching the top of the screw. Crimp the end of the tube to control the flow, or you could use the proper flow restrictor. We did this to the Shizuoka and it works perfect, the oil runs down the screw at about a drop a minute. Might be a bit much oil, but it is well lubed. I can get a picture of it if needed.
    Sep 2016
    46
    You would install a zerk fitting (M6 thread usually) into your ballnut and run a flexable line all the way up and then 180 degrees back down the column to your nut, it will move with the axis up and down. Or do as above ^
    Aug 2009
    13
    Yes please, a picture would be nice. Thanks for help.
  1. G0704 Ball screw choices
    By ny_racer_xxx in forum Benchtop Machines
    Last Post: 02-08-2017, 01:19 AM
  2. G0704 oiling system
    By hscess in forum Benchtop Machines
    Last Post: 10-06-2016, 09:10 PM
  3. Grizzly G0704 CNC Ball Screw Kits on ebay or direct
    By arizonavideo in forum For Sale Only
    Last Post: 02-01-2015, 05:05 PM
  4. Ball screw oiling
    By Lary Alvey in forum Uncategorised MetalWorking Machines
    Last Post: 12-04-2013, 08:40 PM
  5. ball screw/nut oiling
    By timbeaulieu in forum Bridgeport / Hardinge Mills
    Last Post: 07-23-2012, 08:56 PM
