588,613 active members*
5,953 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > CL file not found! V25 lathe..
Results 1 to 7 of 7
    Aug 2006
    673
    Ok, so I bought V25 lathe a few weeks ago, and I've been playing with it on and off since then, but hadn't tried to post and actual code until yesterday. So anytime I try to post anything in lathe, I get a "CL file not found" error. My mill posts fine, and it doesn't seem to matter what post processor I have selected, it just doesn't work. Any one else seen this error before?
    Jul 2005
    194
    Re: CL file not found! V25 lathe..
    I get that sometimes as well, and I am on V27. Have you tried a shorter path? Are you using DropBox by any chance?
    Aug 2006
    673
    I do not use dropbox. I can try making a stupidly simple path (facing or something) and try posting that, but I'm not doing anything overly complex with the paths that I have now. Either way, it should still post the code that I want regardless of the length of the toolpath.
    Is this an intermittent problem for you? I have yet to be able to post anything at all.
    Jul 2005
    194
    Sometimes it works, sometimes it gives me a zero length file, sometimes I get the CL message and it crashes.
    What always, works, is to save the file to a shorter path, and then manually copy it to where I want it to go. Then it works every time if I over-write it.
    Apr 2009
    3376
    Try going to current settings and make sure your machine is correct.
    Upload a file that is doing this
    Dec 2008
    4548
    Quote Originally Posted by jrmach View Post
    Nc filepath.
    Aug 2006
    673
    Quote Originally Posted by BurrMan View Post
    Nc filepath.
    yup, my nc file extension was blank. filled that in and it seems to be working now.
  1. Milltronics "02 - File not found" issue
    By Racecast in forum Milltronics
    Last Post: 04-15-2015, 09:10 AM
  2. Replies: 6
    Last Post: 05-14-2013, 07:43 PM
  3. external reference file paths not found? (ProgeCad)
    By PeteGallo in forum Uncategorised CAM Discussion
    Last Post: 06-14-2007, 02:24 AM
  4. Found a kool link for lathe newbies
    By ZipSnipe in forum Mini Lathe
    Last Post: 03-19-2006, 05:26 PM
  5. I found an old logan 850 lathe for 100 bucks is it worth it?
    By trilect in forum Uncategorised MetalWorking Machines
    Last Post: 06-29-2005, 10:52 PM
