587,252 active members*
3,301 visitors online*
Thread: SEM encoders
    Jan 2009
    64
    SEM encoders
    My mill has SEM servos that had resolvers from a CNC conversion sometime during the late 90s'. I removed them and need to replace them with encoders. The problem I'm running into is finding an encoder for a 17mm shaft that won't break the bank. US Digital carries one for 19mm, could I make a bushing with a 1mm wall? Would I be better off finding an actual 17mm hollow shaft encoder? Does anyone know of a source? I'm looking for something around 1000 cpr.
    Sep 2010
    1765
    how about just using a encoder replacement in a resolver housing? were the resolvers "size 11?" with shaft? Is so, one of this forums sponsors/advertisers, ammc, sells encoder direct replacements for less than a couple hundred dollars i think.....
    otherwise, it sounds like u want a 'kit' encoder to put over rear motor shaft extention? they come in 2 std sizes - 1.8" bolt spacing and another - like 2.2 or something.... most come with a zillion thru hole choices. we sell dynapar (danaher controls), advantech, and ECP brands, and if you want can look and send you choices? pm me if interested with more info?
    Jan 2009
    64
    I decided to go with a piece of tubing over the servo shaft as a bushing and an encoder kit from US digital. Thanks for the reply.
  1. cheap absolute encoders? Oxymoron? Decent Incremental encoders?
    By mattbesquare in forum Benchtop Machines
    Last Post: 09-09-2010, 12:56 AM
  2. Encoders?
    By woodlice in forum CNC Machine Related Electronics
    Last Post: 03-23-2008, 08:00 PM
  3. Encoders for EMC
    By mattinker in forum LinuxCNC (formerly EMC2)
    Last Post: 03-06-2008, 02:55 PM
  4. Encoders
    By ramasule in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 07:27 PM
  5. can I use these encoders
    By cncpete in forum CNC Machine Related Electronics
    Last Post: 09-29-2004, 07:33 AM
