587,657 active members*
8,317 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 92' 88HS - actual feed/speed display?
    Oct 2008
    I have a 92' 3016 with the 88HS control - Is there no way to get the actual rpm and feed rates to display?
    Jan 2004
    3154
    My 94 always keeps a header above the program that is running.
    The header shows all the currently active modal commands, which includes the S and F values as they are set in that section of the program.
    If your machine is calibrated correctly, they are right.
    www.integratedmechanical.ca
    900
    The only way to have the actual rpm and feed rates plus others to display is to upgrade to the dash 5 system.
    Neal
    Oct 2008
    Quote Originally Posted by DareBee View Post
    correct, however if you are using the feed/speed pots to adjust and tune in, it doesn't even display an override percentage so you have to guess how much override you are putting on and do the calculation before going back and editing the program for final version.
    Jan 2004
    3154
    ahha - I see where you are going with that.
    yes I agree, you have to estimate and re-program.
  1. Replies: 4
    Last Post: 08-11-2009, 10:31 AM
  2. Help with Feed and Speed
    By sa6200 in forum Jewelry Design Software
    Last Post: 11-21-2008, 06:48 AM
  3. feed & speed mdf ?
    By frankgranit in forum French
    Last Post: 11-14-2008, 09:18 PM
  4. Haas Graphics Mode - changing display speed?
    By pdoherty in forum Haas Mills
    Last Post: 04-10-2007, 02:57 AM
  5. Speed and Feed
    By kdoney in forum Benchtop Machines
    Last Post: 03-31-2006, 12:21 AM
